Author Topic: O Ring source for fuel use-petcock-CB550K  (Read 2889 times)
Offline newday777
Re: O Ring source for fuel use-petcock-CB550K
« Reply #25 on: May 01, 2025, 10:46:45 AM »
Mine are coming in tomorrow
Stu
My current rides
Prior bikes....
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #26 on: May 01, 2025, 02:23:33 PM »
When I needed a rebuild kit I couldn't find one to save my life. I bought the 4in1 version and it works great. I have my original and it would be great to rebuild it but not only does it have the Orings, the nylon washer and cone should be replaced as well. I can't find thise anywhere.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline newday777
« Reply #27 on: May 03, 2025, 09:56:08 AM »
Ah, I see: does the 2x18mm size fit that face seal? If it does, I'll order up a batch of them at Rocket so we can get them without spending $20 each for them.
Nope not 18mm.
The one surviving from the K5(pre 2010)I have is
     2mm x 18.72mm ID x 21.67mm OD
I opened the petcock today that I put on the K5 in 2019, bought from South Sound.
     1.94mm x 18.49mm x 21.85mm
I picked up the ebay orings today.
They measure 1.78mm x  18.86mm ID x 22.18mm
I have the rebuilt petcock on the K5 now, testing with fresh non ethanol Sunoco 94.
10 minutes no leak so far.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #28 on: May 03, 2025, 10:47:23 AM »
^Stu, is your test with the new o ring just delivered from EBAY?
Offline newday777
« Reply #29 on: May 03, 2025, 10:57:52 AM »
Yes it is. And put in the new Honda 16952-341-671 filter sock kit.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #30 on: May 05, 2025, 01:08:38 PM »
Installed new o ring today in OEM petcock and installed on tank.  The o ring came from the ebay link listed previously in this thread.
So far after about 4 hours no leak.
« Reply #31 on: May 13, 2025, 09:34:16 AM »
Nope not 18mm.
Hmm..those numbers suggest a 2x20mm size(?). I haven't installed the petcock yet on the [book's] 550 in the garage (because the tank isn't painted yet), might see if that size will work on it (?).
I hate to see us all having to pay whole $ for O-rings when they are less than 50 cents in any quantity.
I'm a cheapskate. ;)
Offline denward17
« Reply #32 on: May 13, 2025, 09:40:34 AM »
Mark,
The one I received from Ebay was 1.7mm x 19mm, to fit the 550 petcock.
« Reply #33 on: May 13, 2025, 12:01:58 PM »
Mark,
I'll see if I can get that size, too. The local seal shop can get almost any size made if I buy 100+ of them, and then they are 50 cents or something like it. That's how I make those O-ring kits for these bike engines (which no gasket set has).
