Author Topic: CB500 issues with carbs (I think)  (Read 716 times)
Offline vetlpc
« on: June 27, 2025, 04:02:56 PM »
Hey, I'm new to this world. I've had the bike for a year or 2, but it ran, so I didn't mess with it. Now, I'm having this issue where it will start right away with full choke, but when I try to ride it, it will stall as soon as I let off the gas and won't restart. After I let it set for 30 minutes to an hour, it will repeat the cycle. Any ideas? I grew up working on cars, not motorcycles. Thanks - happy to be here!
Offline denward17
Re: CB500 issues with carbs (I think)
« Reply #1 on: June 27, 2025, 04:47:34 PM »
Welcome to the forum vet !
Are you releasing the choke after you get it started and start to ride?
Can you get it to idle at all?
More info needed.
Online Deltarider
« Reply #2 on: June 28, 2025, 01:30:05 AM »
Vetlpc, let's start at the begin. Have you read the starting procedure as described in the Owner's Manual? https://www.honda4fun.com/dwnload/Owners-Manual/CB500-K1-Owners-Manual.pdf
Every owner of a CB500 is advised to read carefully the starting procedures.
Pay extra attention to STARTING IN EXTREME COLD WEATHER in the CB500 Owner's Manual p.29.
Whenever my CB500 has stood for four days or longer, I need this procedure. The reason we need this  more than back then, lies in the changed properties of gasolines.
Then this: as far as our model, one is not supposed to start riding with the chokes still (partially) closed. Honda wanted you to have both hands at the handlebars at all time. To compensate, you start riding with a somewhat raised idle. Some achieve this by keeping the throttle grip somewhat inward, as the Owner's Manual suggests, others find it easier to turn the idle adjuster knob (under the tank) somewhat to raise the idle, after a mile or so, they readjust that knob, say at a traffic light or so.
BTW, when the engine is warm enough, I recommend an idle of minimum 1150 rpm at all time.
CB500K2-ED Excel black
« Reply #3 on: June 28, 2025, 03:37:04 AM »
When it won't re-start, whip out the #1 plug and see if it is wet or dry.  Try it again and have a look at #4.  If they are wet, it's getting too much gas.  If dry, not enough.  While the plugs are out, might as well do a quick check for spark.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: June 28, 2025, 05:22:01 AM »
Did it sit for a while, over winter? Have you put fresh gas in it?
Offline vetlpc
« Reply #5 on: July 01, 2025, 08:58:27 AM »
Thanks!
Yes, pretty much as soon as I start riding to get the engine to smooth out.
It will idle when I first start it. Once I start riding it, it is difficult to get it to idle.
Offline denward17
« Reply #6 on: July 01, 2025, 10:08:04 AM »
If idling too low to stay running you can adjust the one thumb screw under gas tank on right side.
