Hey everyone,
I’m finishing up a full rebuild on my 9/71 CB750 K1 and could use some advice. The engine is running and sounds strong overall, but after a few startups and heat cycles, I’ve noticed a tapping or clicking sound coming from the top end. The noise is coming form the top left only. It seems to follow RPM and sounds like it’s coming from the rocker arms or somewhere in the head.
Here’s a quick overview of the build:
• Stock displacement with 10.5:1 compression pistons
• Head and crank work done by Ken at Cycle X (balanced crank, lightened rocker arms, new valves, springs, titanium retainers and jam nuts)
• CX-1 cam
• Stock airbox with a UNI foam filter
• Delkevic 4-into-1 header into a Cone Engineering 18” Quiet Core muffler
• Stock carbs (still dialing in jetting)
I primed the oil pump before first start-up and there were no unusual sounds at first, but now that it’s run a few times, this tapping has become noticeable. The bike is mostly assembled, but I’m using the Cycle X frame splice kit, so pulling the valve cover is easy if needed.
I also did the cam tower mod added 8 oil holes shown in page VI A-22 in the HondaMan, My CB750 Book. Maybe I drilled too close to the edge and part of the cam tower broke under load so it is making that clicking noise.
Thanks in advance,
Dan
