I was thinking of modifying the stock aluminum brackets where the pegs are mounted, to a similar position as the raask set up.
Check out where the pegs are located on their plates.
Now check out our stockers the hole where the pegs go are all the way in the front. (to the right in the pic.) As long as this spot where the pegs hole would be doesn't hit a structural rib on the back side, we should be in good shape. Some kind of backing plate would be needed though. and we would definetly need to change the controls , I'm guessing some kind of newer gear with adjustable legs would work well.
I wish we had more options other than raask and tarozzi............. Cheaper options!
Let me know if you come up with other options.
Peace,
Paul Z.
