Author Topic: how am i going to sort the brakes on the chopper ?  (Read 1093 times)
Offline spotty
« on: July 17, 2025, 06:42:16 PM »
the wheels i've got are invaders with disc front and drum rear.
however i don't want to have any levers/cables on the bars ( will be setting the bike up with internal throttle and clutch, which i can get from India )
what i wonder is if there is a way to set up both ends brakes operating off the rear pedal. If it was a disc rear it'd be easy, just plumb both lines into a car proportioning valve.
i'm not sure whether it would be practical to attach the m/c down below as it would be hard to get the correct pressure ( slightly less on the rear compared to the front ) differential without either getting too much/not enough on one or the other.
any ideas ?
i blame Terry
Re: how am i going to sort the brakes on the chopper ?
« Reply #1 on: July 17, 2025, 08:21:52 PM »
You need to check your local laws first, here in UK you MUST have 2 independant braking systems
Offline spotty
« Reply #2 on: July 17, 2025, 10:36:59 PM »
Same here but as there's sod all chance of legally registering it with the 70's US frame, it will be sharing a number plate with another bike which will be (almost) legal
i blame Terry
« Reply #3 on: July 17, 2025, 11:08:41 PM »
I would keep a brake lever on the bars, but maybe mount the MC remotely and operate it with a cable? You are still going to have a clutch lever aren't you?
Offline Alan F.
« Reply #4 on: July 18, 2025, 07:45:24 PM »
I don't want to have any levers/cables on the bars ( will be setting the bike up with internal throttle and clutch, which i can get from India )
My first thoughts went to the Goldwing GL1100 with the linked braking system, when you press the brake pedal one front disc and the rear disc are applied. I wonder how tough it would be to add a hydraulic actuator to your rear drum's brake actuator rod?
Offline spotty
« Reply #5 on: July 18, 2025, 10:02:47 PM »
No, won't have a clutch lever, that'll be an internal twist like the advance/retard twistgrip on an old Harley. You can get brand new throttle and clutch setups from India for inch bars.
i blame Terry
Offline spotty
« Reply #6 on: July 18, 2025, 10:04:52 PM »
Good idea, I have a hydraulic ram I was going to use to convert the clutch on the dirt bike, I will have to look further at that, thanks for your brain power
i blame Terry
