I had a long post, but decided to give the short version for now. 1995 Kawasaki zx600c runs badly. It doesnt want to rev at all, just idle. I have changed gas in the tank several times, cleaned carbs half a dozen times, changed to another set of carbs, adjusted valves, checked valve timing, checked ignition timing, changed ignitor box, checked compression (130 or more) ohmed ignition trigger coils, ohmed primary side of coils (my meter only goes to 1000 ohms) set pilot screws to 1two turns out and nothing helps. All four pipes get hot, so I know all cylinders are firing. I'm going to order some new plug wires, caps, and plugs today, and in the meantime clean all my connections. Any ideas from the old school crew?
