Author Topic: Clutch Question. Thoughts?  (Read 731 times)
« on: August 11, 2025, 06:53:37 AM »
Last week I installed a new chain and sprockets on my 1973 cb750K. My son usually rides this bike and the last time we rode together for a few days, I spotted some very worn sprockets…..
Yesterday I put +100 miles on the bike. It runs great but when starting off from rest there is a slight “judder” and hesitation. When Ihad the Lester wheel off last week, I checked the rubber snubbers in the cush drive and they were dry and perfect. I suspect this poor engagement is caused by the cush drive behind the clutch basket? Anybody confirm my suspicions?
I’ll probably pull the clutch apart this week to make sir there is nothing falling apart in there, just incase…….
« Last Edit: August 11, 2025, 07:52:53 AM by BenelliSEI »
Re: Clutch Question. Thoughts?
« Reply #1 on: August 11, 2025, 08:00:34 AM »
Could it be the oil in the engine?
« Reply #2 on: August 11, 2025, 10:02:06 AM »
Honda GN4 10W-40. Same as all my other bikes……
Online HondaMan
« Reply #3 on: August 11, 2025, 10:06:43 AM »
That bike is the color mine was when I bought it! Nice condition!
Offline CycleRanger
  • No comment about being an
« Reply #4 on: August 11, 2025, 10:10:10 AM »
It could be the basket but that's not the first thing I would suspect.
Could be a couple of weak clutch springs or slightly warped or sticking steels or plates.
« Reply #5 on: August 11, 2025, 10:14:45 AM »
I hope you’re right! Maybe a broken lifter plate? I have a few new sets in my stash, so will pull it all down when it cools off a bit here!
« Last Edit: August 11, 2025, 10:16:54 AM by BenelliSEI »
« Reply #6 on: August 11, 2025, 10:15:49 AM »
The engine has never been opened up in this one. It runs so well I rarely touch it! Will pull apart the clutch next.
« Last Edit: August 11, 2025, 10:17:41 AM by BenelliSEI »
« Reply #7 on: August 11, 2025, 10:38:21 AM »
There is no "cush drive" or dampers behind the clutch basket.
http://forums.sohc4.net/index.php/topic,205513.msg2322391.html#msg2322391
Online HondaMan
« Reply #8 on: August 11, 2025, 12:32:21 PM »
K3 era: look closely at the friction surface of both the top (pressure) plate where it contacts the cork plate, and the similar surface at the back (hub) of the stack. In the early K1 and again in the early K3 bikes, these could warp a little bit (they were still largely hand-cast parts at the Old Factory). It will be obvious if this is the case: a portion of the surface will show wear marks and a portion won't.
The New Factory bikes were receiving nice injection-molded parts by then.
« Reply #9 on: August 11, 2025, 01:01:51 PM »
Thanks for all the clarifications! I will post what I find. The engine is tuned and the carbs are perfectly sync’d. Definitely a clutch issue…..
« Reply #10 on: August 12, 2025, 07:47:01 AM »
I put in a lifter plate made by someone here on the forum, it's pretty nice, forget who made it.
« Reply #11 on: August 12, 2025, 10:16:07 AM »
I have a couple of NOS ones that came with the stuff I bought from Flybackwards….
No excuses.
Offline Honda Hansel
  • Sherwood Park AB
« Reply #12 on: August 13, 2025, 03:17:19 PM »
There is a cush drive on the inside of the primary drive sprocket
The cases need to be split to get them out
Cycle X makes a kit for that problem
If my memory serves me right
Just put in a new EBC clutch kit in my beloved K7 and works good now
Plates and springs $ 117.00 Ca
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
