Author Topic: What did I do to it?  (Read 452 times)
Offline vince.whirlwind
« on: August 23, 2025, 07:01:17 AM »
1978 CB 550K. Long day at work. Engaged the starter not realizing bike was in gear. Bike chugged forward about 6” with starter turning over. Now, when the bike is coasting, in gear with the clutch engaged, slight knocking is coming from the gearbox. What did I do to it? 🤦🏻‍♂️
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: What did I do to it?
« Reply #1 on: August 23, 2025, 07:43:33 AM »
Maybe damaged the starter clutch?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2 on: August 23, 2025, 08:38:52 AM »
Thanks
Offline newday777
« Reply #3 on: August 23, 2025, 11:14:43 AM »
Did the bike fall over onto the shift lever? If so, most likely pushed the shift lever in and damaged the shift forks and shift drum
Stu
My current rides
Prior bikes....
« Reply #4 on: August 24, 2025, 04:07:14 AM »
Thanks
Offline newday777
« Reply #5 on: August 24, 2025, 04:24:46 AM »
Stu
My current rides
Prior bikes....
Offline Little_Phil
« Reply #6 on: August 24, 2025, 09:43:03 AM »
So do you mean when you pull the clutch in and coast the noise disappears?
« Reply #7 on: August 24, 2025, 11:10:21 AM »
I would check the main chain tension at several points
