Author Topic: Can my master cylinder be saved?  (Read 658 times)
Offline slyguy
« on: September 16, 2025, 07:10:06 PM »
As my friend Forest Gump would say, stupid is what stupid does isn’t it? I made great progress today reassembling & emptying a bin & a couple more boxes! I was ending doing new levers from yamiya & the m/c side was very tight & not returning properly so I tried tweaking the slot a tad, felt a bit better so I went again & F#*k! Is it possible to heli arc or weld to repair or is it trashed? And….is so, anybody got one?
Offline CycleRanger
  • No comment about being an
Re: Can my master cylinder be saved?
« Reply #1 on: September 16, 2025, 08:39:11 PM »
That one is pretty much done.  :(
Fortunately aftermarket replacements are available and not terribly expensive.
Offline pjlogue
« Reply #2 on: September 17, 2025, 04:44:31 AM »
I think CycleRanger is correct.  The cost to repair properly and safely far exceeds the cost to replace.  either get a new aftermarket one or used one off Ebay and rebuild that.  Rebuilding a MC is not hard.  Just be sure the used MC has a clean bore and is not pitted.
-P.
Offline newday777
« Reply #3 on: September 17, 2025, 07:35:22 AM »
Replacement time. That is trash bin fodder
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: September 17, 2025, 07:45:20 AM »
not returning smoothly is likely caused by the center pivot bolt
Get a new one
1973 CB 750 K3
10/72 build Z1 Kawasaki
