Author Topic: 1976 cb750A Front LEFT Engine Mount  (Read 4354 times)
Offline BenelliSEI
  • 1969 cb750
« on: September 22, 2025, 02:05:15 PM »
Looking at pictures of “Guts” 1976 cb750A restoration from back in 2022. Superb work! I noticed the front left engine mount is a fabricated unit, two plates with bolts. I’ve often wondered why the 1977 cb750K has this special mount and it then went back to the welded lug style for 1978 cb750K. I’ve never seen a reasonable explanation for that single year variance. I wonder is the cb750A frame identical to that year cb750K? Is that removable mount required to get the cb750A engine in and out of the frame? Picture is the cb750A. Looks the same to me. Interesting…
« Last Edit: September 22, 2025, 02:08:35 PM by BenelliSEI »
Re: 1976 cb750A Front LEFT Engine Mount
« Reply #1 on: September 23, 2025, 07:31:33 AM »
Hey John....seem to recall this conversation a year or so ago and an explanation was never determined?
I've never had or even seen an A model in person but am still curious too.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: September 24, 2025, 05:38:34 AM »
Steve…. Me again. I keep bring it up. I find it extraordinary that with all the detail we have on just about any detail of this model, this one has never been explained. Seeing this bracket on the cb750A seems a clue?,
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: March 01, 2026, 07:07:24 AM »
The more you look at the 750A, the more it appears to be an almost custom hand made production bike. Pretty unique and very ahead of its time. Only Honda could pull something like that off.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: March 01, 2026, 12:18:51 PM »
That's much the way Honda made the CB750 sandcasts, too! Still today I get to see [what I call] 'special' parts from those bikes. The first year "A" is quite different from the later ones as well. Then, there's the early vs. late K8...and the early vs. late F1...and the 3 different engines of the K6...
I also just disassembled (for rebuild) a [very] customized CB500K0 that someone has fabbed a hydraulic clutch lifter into the left side cover. After I gather more pix I'll put it in a post. Last night I disassembled the clutch side of the engine, finding an 8-plate clutch and many missing shifter pieces, like the ratchet that ensures only 1 gear-at-a-stab can happen. I don't think the owner knows about this 'feature' (yet), so I have some documentation to do first. The whole engine is bathed in oil leaks from whoever took it apart for these mods: the gaskets are thinner than any I have ever seen before, making me suspect even they were handmade(?). The head gasket was so soaked that it just lifted off the cylinders, and it looked to have been a re-used one. The rest of the bike is very customized, too, but I only have a picture of it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: March 09, 2026, 09:43:34 AM »
Too bad, “customized” often means butchered, unfortunately. Many such bikes are almost worthless without extreme repairs.
1973 CB 750 K3
