Author Topic: 2 cylinder not firing  (Read 952 times)
Offline cr0issqnt
« on: September 24, 2025, 07:24:39 PM »
I just got my bike together and running yesterday but at first only cylinder 2 and 3 were firing and so I cleaned the points and checked the bullet connectors at the coils which fixed it, but now cylinder 2 doesn't fire which leaves me stumped. I checked spark, I saw and felt it so my only guess now is the carburetor to check for fuel. I don't really want to tear the bike apart having just got it back together and knowing that cylinder 2 was just working. Is there anything missing that I am not thinking of?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: 2 cylinder not firing
« Reply #1 on: September 24, 2025, 07:58:48 PM »
Check the simple stuff first.  You could have just fouled that plug.
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #2 on: September 25, 2025, 02:24:16 AM »
 It has surprised me in the past how good a plug can look and still not fire. You can swap with another one and see if the miss follows it.
« Reply #3 on: September 25, 2025, 08:32:14 AM »
Are the condensors new, and where did you get them?
Offline cr0issqnt
« Reply #4 on: September 25, 2025, 02:56:03 PM »
I cleaned up the spark plug with carb cleaner and a toilet brush I use for cleaning more delicate things and I left it overnight to cool down I still don't think it is working. i will let it cool down and try and switch plugs around. The condensers are not new.
Offline cr0issqnt
« Reply #5 on: September 25, 2025, 03:46:34 PM »
I just switched the plug for cylinders 1 and 2 and still the exhaust from cylinder 2 feels cold
« Reply #6 on: September 25, 2025, 07:38:33 PM »
Do you have an ohmmeter? If so, check the resistance of the sparkplug caps on the #2 and #3 plugs. They should be within 800 ohms of each other (if they are around 5000 ohms). If they differ by more than about 1500 ohms, then only one plug of the 2 on that coil will usually fire.
If the plug caps are the higher-resistance type (10,000 ohms) then they should not differ more than about 2000 ohms.
Offline cr0issqnt
« Reply #7 on: September 25, 2025, 09:01:50 PM »
I think I am doing this right but I am not sure how to read it right. I have both probes touching the wires that go into the spark plug caps and this is the reading.
« Reply #8 on: September 29, 2025, 07:23:09 PM »
I think I don't quite understand what you're measuring? If one probe is in one of the sparkplug caps of a coil and the other probe is in the other sparkplug cap (like, 1 and 4 or 2 and 3) then those plug caps are pretty good. If the probes are in just one plug cap, that one is burned out: it should read closer to either 5.00 (K ohms, which is x1000 times the reading on the screen) or 7.50.
Offline cr0issqnt
« Reply #9 on: September 29, 2025, 08:46:06 PM »
Yes one probe was in one spark plug cap and the other was in another.
I did take take off the carbs and sprayed around in there today and that seems like it was the fix I should have posted that I had.
Offline M 750K6
« Reply #10 on: September 30, 2025, 05:30:45 AM »
......... They should be within 800 ohms of each other (if they are around 5000 ohms). If they differ by more than about 1500 ohms, then only one plug of the 2 on that coil will usually fire......
Obvious once you are told, but this by-product of wasted spark systems had never occurred to me.  Thanks for sharing.
« Reply #11 on: September 30, 2025, 07:53:28 AM »
One could put this to a test: have one R(esistor) plug (5kOhm) and the other standard (zero) and see what happens. :)
