It came with a Haynes manual, mini gauges, 3ohm dyna coils, k&n pod filters, keyster carb rebuild kits, some smaller aftermarket indicator lights and probably some other misc bits and pieces I've forgotten about..
A closer look reveled a lot of damage which seemed cosmetic at the time, gauge clusters bashed, front and rear fenders dented, headlight cracked, rusted out seat pan, rotten header and exhaust, worn fork stanchions etc etc. The PO had already fitted the coils, and rebuilt the carb with the keyster kits.
An old neighbor into his Harleys and previously owned GB honda's back in his younger days offered to come have a look and we put some fuel in the tank and surprisingly it fired up after a few attempts...
Not sounding too healthy there was a smoke everywhere, fuel pissing out of the carb but he was brave enough to take it up the road...it ran and he came back after 200m and said..."it seems like a good starting point"..
I immediately started digging into it a bit further and came across this site...I went through the carbs and found a fuel valve upside down, a missing main jet holder. I fashioned a replacement out of some steel and had a friend patch the header ready for its second attempt..
Much of the same and after some researching I realized my points plate needed replacement as well as the plug caps and the coils were the wrong ones. Some communication with HM and after a few weeks I had a new points plate, plug caps and a resistor pack for the coils...he suggested I fit one pod filter in the standard box which I managed to knock up in the workshop..
Much the same result however with fouled plugs...I pushed forward starting to clean up some other parts of the bike while digging further and further into this site researching as much as I could..
