No, the dyno on a Honda charges the battery rather than feed the ignition directly. If it has 12.5 or so volts it should make a spark.
If the plugs got wet with bad gas they might need to dry out before they will work. You might as well get used to cleaning the carbs, todays gas plugs the pilots whenever a bike sits for a while.
