Author Topic: Engine Test Bench  (Read 3498 times)
kaybee
Engine Test Bench
« on: May 21, 2007, 04:07:48 PM »
Heres the test bench I rigged up. I wanted to get some load on the engine and run a few gears. The first clip is just before startup. Some focus on the airbox that I modified. I wanted to keep the origional design with the upper velocity stack chamber and just dress up the lower filter chamber a bit.
 For the load on the back tire, I used an unroadworthy tire and a 2x4 pressed againt it for some drag. I used a bungee cord for tension. Call it redneck riggin but it worked just fine heh...
 OH..btw, the niose in the background is the shop exhaust fan.
Clip 2 was the firs attempt but had the bungee a little too tight...
Here we go...3rd gear SMOKE SHOW...YEE HAAAA
« Last Edit: February 12, 2011, 01:56:22 AM by SteveD CB500F »
