Author Topic: 1977 cb 550f oil pan question  (Read 891 times)
Offline mikerider
« on: November 07, 2025, 03:02:56 PM »
Do I have to take off the exhaust  pipes to get to the oil pan bolts on the exhaust side?
Sent from my SM-S926U using Tapatalk
Re: 1977 cb 550f oil pan question
« Reply #1 on: November 07, 2025, 03:29:35 PM »
Probably
« Reply #2 on: November 07, 2025, 06:11:46 PM »
It always seems like the #3 exhaust pipe wants to be right up against the side of the oil pan: I then loosen the #3 and #4 header clamp nuts and the rear footpeg (hanger) bolt for the mufflers and wiggle them away from the oil pan to help reach those bolts.
Don't forget to re-tighten it all afterward - like I've done more than two or three times... ;)
Offline mikerider
« Reply #3 on: November 08, 2025, 09:53:16 PM »
OK that all worked out fine got the oil pan on and everything is fine with that but, I still have  a leak from the top of the oil cartridge a d runs down on the floor..  where could it be running from.
« Reply #4 on: November 08, 2025, 11:52:10 PM »
Do you mean the oil filter housing?
If so there have been reports of some pattern oil filters having O rings of a too small cross section
Offline newday777
« Reply #5 on: November 09, 2025, 02:49:29 AM »
As Bryan said, aftermarket orings for the oil filter housing and the oil filter bolt are junk and are either too big or too small depending on which aftermarket oil filter you buy. I trash can the orings from any aftermarket oil filter and only use Honda orings to be sure there aren't any leaks(in all of the engine). It's been that way since the 1970s when I was a parts manager.
Stu
My current rides
Prior bikes....
« Reply #6 on: November 09, 2025, 01:56:56 PM »
In the USA, if your new oil filter came with a new large O-ring, it is 100% likely the O-ring is too thin. All the other bikes that use the filters use thinner O-rings than Honda: Honda's own is 4.5mm thick and yours is likely to be 3.5mm thick if the wrong one. I have replaced a bunch of cracked oil filter housings that broke from  frustrated owners trying to crank them tighter.
Honda's part is:
91316-425-003
O-RING (89X4.5)
Offline piefairy
« Reply #7 on: November 12, 2025, 06:16:18 AM »
Anyone know if the one that comes from vintage cb750 is the correct size? I have some on order with the new filter.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: November 12, 2025, 07:26:18 AM »
I’ve used a few (most recently buy in bulk on EBay for 1/2 the price) of theirs and I think they worked just fine.
