Author Topic: The CB550 that came in from the cold  (Read 7839 times)
Re: The CB550 that came in from the cold
« Reply #25 on: December 29, 2025, 12:03:06 PM »
Just a quick update: Found out why the clutch lifter wasn't working.
Fixed it  :P
What was "up" with the lifter?
Offline rb550four
« Reply #26 on: December 29, 2025, 12:34:12 PM »
  Some guys use carb clean spray , I like to soak mine in carb cleaner ....it's getting hard to find here in NY  a bit toxic I guess  but that's what I use until I find a better way . Honda man is right , never do this stuff without eye protection !
And I have found if you can't get it clean with a spray can you may find it better with a cheap pancake compressor if you don't have a big one. One last thing , super glue for the corners of the float bowl washers.
Offline newday777
« Reply #27 on: December 29, 2025, 05:32:05 PM »
Fixed it  :P
Check the spring in the pictures
Stu
My current rides
Prior bikes....
Offline ThelassianLupus
« Reply #28 on: January 04, 2026, 10:32:25 AM »
Thank you very much for reiterating these tips. I've had one close call with carb cleaner spraying back into my face, thankfully I do wear my glasses on shop days. And the thought has occurred to me several times that an air compressor would do a lot better than my soaking, picking, and scrubbing. Maybe if I time its usage while nobody is around to hear it. Say for instance, the EMT guy sleeping off the night shift whose space I'm borrowing.
« Reply #29 on: January 04, 2026, 11:35:04 AM »
Fixed it  :P
Yeah, I should also elaborate that wasn't the only problem, just an oversight that was interfering with my adjustment of the lifter arm. HondaMan mentioned previously:
"First, I'll mention about the clutch plates you have: the 2.8mm thick plates are the ones Vesrah (i.e., generic imported plates) is lately selling in place of Honda's 2.71mm thick versions. In that regard, they should work OK."
The 2.8mm plates do result in a stack height that allows for adequate pressure plate separation while the clutch lifter arm is positioned correctly (horizontally aligned to arm and case markings). I had incorrectly assumed that I needed to increase the stack height from 31.6mm (with the 7 Vesrah plates), to something closer to 34.4mm (I assumed 7 factory plates would make this figure). I sought to accomplish this by swapping in three CB750 friction plates of 3.5mm thickness adding up to a stack height of 33.7mm (above wear spec as listed in my Clymer manual.
Now this is more or less the thought process I was approaching the problem with. Shifting problem=clutch problem, clutch problem: arbitrary stack value is lower than spec/ I think it's incorrect because it doesn't match what my books or the Internet says. Therefore the solution must be to come up with a new arbitrary stack height, replace parts until it's closer and then wonder why it still doesn't work..... I realize that I failed to consider the actual mechanics of this component and that's how something obvious like the lever spring having slipped behind the actuator went unnoticed while I was fixated on the friction plates.
The only parts I ended up replacing were the springs (swapped them out for weaker ones) and one friction plate. The clutch seems fine now, when I ride again I'll see how the bike shifts.
It's awesome to have access to the knowledge, knowing how to apply it is what takes real skill.
« Last Edit: January 04, 2026, 11:37:29 AM by ThelassianLupus »
« Reply #30 on: January 05, 2026, 03:22:01 AM »
Anyway, on to my next question.
I found these jet replacement kits that I had purchased when I first got the bike. I'm pretty sure I got them from Common Motor Collective. I don't believe they are genuine Keihin parts, so the only pieces I'm considering to use are the o-rings.
I've replaced the drain plug rings, and I'm looking at other o-rings to swap. The replacement main jet from the kit seems to have a ring that's both too small and too wide. The dry fit was too tight when I tried seating the new main jet, it wouldn't go in completely. Yet it seems to not fill the groove on the main jet entirely either. I suppose this is why I've heard that the factory main jet has a "custom" o-ring.
My questions are, how would I know if I needed to replace this ring? And if I need to replace one, should I replace them all across the three other carburetors?
« Reply #31 on: Today at 05:13:51 AM »
Long overdue update, not much has changed but I still want to keep the thread.
I've moved on from the carbs, they're rebuilt and waiting for me to finish checks to the wiring harness before going back on the bike. Despite a long winter, riding season has already begun here in Maine and I'm itching to get on the road. The biggest hurdle to that right now is repainting the gas tank and body panels. I have my Eastwood order set out on the bench, so that this Friday when it gets to be over 50° outside I can get started.
I recently had an awesome opportunity to travel to New Hampshire with my dad and visit Steve from hondarestoration.com. Got to look through his collection, buy some parts, and met two forum alumni AlanF and Newday777! Super great to chat with you both. Look forward to running into you again.
Offline denward17
« Reply #32 on: Today at 06:12:35 AM »
Good Luck on the paint, I'm sure it will turn out great.
Yes, Alan and Stu are good people....
Offline newday777
« Reply #33 on: Today at 07:09:52 AM »
It was great meeting you and your dad too! Hope to catch up with you again.
Paint likes 70° and above....though we could be seeing that here on Friday.
Stu
My current rides
Prior bikes....
« Reply #34 on: Today at 09:28:56 AM »
Sorry to "drop out" of the thread: my wife got real sick and was undergoing many (MANY) tests and [bad] doctor visits, trying to pinpoint the cause. I was a little too occupied with that stuff. :(
« Reply #35 on: Today at 12:24:25 PM »
Mark, I'm really sorry to hear that. Always glad for your input, no apologies needed.
How is she now?
