So I just installed a set of All Balls tapered bearings on my '73 CB 750. I'm certain all the races are seated and the correct washers are being used and in the correct position/order (per the instructions). The thing is that now when re-assembling the front forks (in particular the upper fork covers), there seems to be about an extra 1/8" gap between the top of the cover (with the upper isolator in place on the cover) and the under side of the top bridge (triple tree). I seem to recall when disassembling there was little to no gap and the covers were slightly wedged in place. It's almost as though the upper and lower triple tree are now a little further apart? I disassembled the triple tree to double check that the races are seated properly and the bearing on the steering stem is also seated properly (there does not seem to be any gaps that would account for the 1/8" gap I'm seeing up top).
I also tightened the spanner nut to the point where everything was pretty snug and a bit of turning resistance and then backed off about a half turn until turning was nice and smooth. So it seems as though all the parts are compressed properly.
The only thing I can think of that would make up this difference is the washer under the bearing and dust cover on the steering stem. I did the measurement of the old bearings and ended up using the thinner of the two washers provided in order to be within the +-1mm height measurement specified in the instructions. Also the steering stops seem to be right where they should be relative to the steering tube stop plate.
Is it normal to have a little gap where I'm seeing it? Just trying to check my work.
Thanks!
Bill
There are 2 or 3 (depending on when you got your All Balls kit) large washer-spacers in the All Balls kits. One of them goes above the lower bearing shell, in the bottom of the triple tree, before installing the tree. Honda changed the spacing in the 750's steering head 3 times alone, and just made long threads on the steering stem to make them all still fit together, regardless of year of manufacture. So, All Ball's instructions tend to be vague about which spacer to use, also partly due to how many different bikes their kit will fit.
Measure the "gap" that you have when the fork ears (with their rubber seals on top) are placed into the upper & lower trees to see how big the gap is, then select the washer from the All Balls kit that is that same thickness, or slightly less. Then remove the bottom race (a long screwdriver will let you tap it back out) and install it again, but with that spacer above it. Then it will all fit together.
Annoying, but still WAY better than it used to be before All Balls kits came along.
