Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Yep, the original Gold was painted over a silver base. I still do it that way. The plastic was sometimes a light tan color, like beige, and sometimes much darker. That's interesting about the missing "HM" in the wing logo! I haven't seen that before.
Quote from: HondaMan on December 04, 2025, 09:29:14 AMYep, the original Gold was painted over a silver base. I still do it that way. The plastic was sometimes a light tan color, like beige, and sometimes much darker. That's interesting about the missing "HM" in the wing logo! I haven't seen that before.It seems all the aftermarket “diamonds” are missing the HM. Honda chased down the manufacturers and made them stop.
It's like being a kid on Christmas morning. 😁
New gas tank mounts. The front mounts were in decent shape and still usable - truly amazing for 55 year old rubber. Back rubber completely disintegrating and crumbling but still did its job and kept the tank firmly in place. Very impressed with the new NOS Honda rubber. Very heavy and high density perfect for absorbing the weight and movement of the tank. Will the new rubber last another 55 years? Friday was a holiday here in Thailand so Yamiya body set delivery is scheduled for Monday
Aha . . . the toasted marshmallow . . .
Quote from: kyle750 on December 04, 2025, 09:50:42 PMAha . . . the toasted marshmallow . . .Marshmallow. Is that a flasher unit hanging behind the coils? Usually that goes in behind the battery box.
Quote from: BenelliSEI on December 06, 2025, 06:13:29 AMQuote from: kyle750 on December 04, 2025, 09:50:42 PMAha . . . the toasted marshmallow . . .Marshmallow. Is that a flasher unit hanging behind the coils? Usually that goes in behind the battery box.I believe the marshmallow is for the JDM overspeed warning indicator red light. On my CB550 the marshmallow is located inside the headlight bucket
Believe me the only washer guaranteed to work are the THICK red original type fibre washers, a reasonable amount of time the "dowty sealing" type washer will work
A quick check - The early Honda CB750 and early CB500/550 use the same petcock? Petcock on right side of the tank on the CB750 and left side on the CB550. Off/Stop lever arm position is pointed forward on the CB750 and pointed back on the CB500/550.I'm sure to mix this up and get it wrong
