Author Topic: Before Paint Engine Pics  (Read 1020 times)
Offline TideWater2
« on: December 22, 2025, 02:46:05 PM »
Does anyone take pics of the engine case after prep and before paint? The more I work on this the dumber I'm getting and seams like I'm going backward.
I used aircraft paint remover, a bottle of cold piss would have done the same.
Thanks
3 - 1971 CB750 K1s
Offline denward17
Re: Before Paint Engine Pics
« Reply #1 on: December 22, 2025, 03:54:18 PM »
I used sand paper with small sticks (popsicle) and many hours.  Also used a dremel tool with course sanding wheels.
I did use the aircraft paint stripper on a couple of tanks, works better if roughly sanded before applying, and wet it good with the stripper.
Top of case shown in picture, about mid-way through process.
« Last Edit: December 22, 2025, 03:58:10 PM by denward17 »
Offline TideWater2
« Reply #2 on: December 22, 2025, 04:15:25 PM »
Thanks denward17, that helps a lot. I'm not as far along as your pic, but was wondering if I was doing it right. Its like refinishing an egg yoke, to mild nothing happens, a tad more aggressive and the blocks scratches and melts.
3 - 1971 CB750 K1s
Online BenelliSEI
  • 1969 cb750
« Reply #3 on: December 22, 2025, 04:47:53 PM »
Don’t worry too much on the finish, just make sure it is clean! If you plan on using Duplicolor Engine paint note that Duplicolor also makes a “Filler-Primer”. I’ve used it on a really rough block and then covered with the engine paint. Works great!
« Reply #4 on: December 22, 2025, 04:49:05 PM »
I do it the easy way: I take everything out of the cases and take them to the machine shop (along with $120) and have them put thru their washing machinery. Then they bead-blast the results, and they are so clean they are ready-to-paint, right from there. (Top ends, too.)
Lazy, but pretty! :D
« Reply #5 on: December 22, 2025, 04:49:59 PM »
+1 on this filler-primer: it helps with the tiny crack-like surface glitches, especially in the early engines.
Offline TideWater2
« Reply #6 on: December 22, 2025, 04:57:13 PM »
Thanks BenelliSEI and Hondaman,
I will for sure use the primer. I did not tear the motor down, it was running good so it makes it a little tougher. I get a little lost and frustrated when I'm left to my own skills, lol.
3 - 1971 CB750 K1s
Offline denward17
« Reply #7 on: December 22, 2025, 05:21:29 PM »
I used the primer/filler and then the Dupli color paint on mine, see pics....
Case, cylinder and head were painted, the covers were polished.
Offline TideWater2
« Reply #8 on: December 22, 2025, 05:38:57 PM »
Looks great, hope mine turns out that good. Thanks
3 - 1971 CB750 K1s
Online BenelliSEI
  • 1969 cb750
« Reply #9 on: December 23, 2025, 09:29:50 AM »
I didn’t have to bother with the filler primer on the Sandcast. Rough is what makes it a Sandcast and it adds “character”. Easiest one i ever had to prep!
Offline kerryb
  • Not a very
« Reply #10 on: December 24, 2025, 09:24:08 AM »
I make o-ring brackets to seal the openings, & then use the soda blaster.  It has to be clean first, soda won’t dislodge grease in the corners.  The soda comes off best with the power washer.
Offline TideWater2
« Reply #11 on: December 24, 2025, 10:13:45 AM »
I should probably give a little back story to this project. I did have the engine dry ice blasted, which cleaned it very well, but did nothing for corrosion just as the blaster guy said. I think most here would have tore the motor down and I would agree with that, I just not at that level yet.
3 - 1971 CB750 K1s
Online newday777
« Reply #12 on: December 24, 2025, 10:32:33 AM »
Here is a K4 just before paint in 2020 that a friend had
Stu
My current rides
Prior bikes....
Offline TideWater2
« Reply #13 on: December 24, 2025, 11:42:08 AM »
Damn, that looks good enough to keep to me. I have more Dremel sh*t coming so I'll keep going.
Thanks
3 - 1971 CB750 K1s
Offline EZduzit
« Reply #14 on: December 24, 2025, 12:08:00 PM »
Nice neat job. Shows dedication to producing quality work, which is mostly in the prep.
Anything seems possible when you don't know what you're doing.
