Author Topic: Nipples  (Read 321 times)
Offline britman
Nipples
« on: December 30, 2025, 10:08:37 AM »
Yep, figured that would get your attention.  I posting this thread for those of you who know your way around a machine shop and appreciate one off creations.  As you all know I now have a Harley Davidson Servi car.  I noticed when I first got the bike home the manifold was aftermarket and secured with stainless steel bands, the OEM set up secures with large nuts and copper bushings that tighten down on threaded nipples in the intake on each cylinder.  I thought I would convert it back to stock and bought an OEM manifold and all of the hardware figuring the aftermarket system was an early kit to run a newer style Mikuni carb and easily replaceable.  When I pulled it apart I found cylinder inserts that had replaced the stock nipples and the bands secured rubber o rings that hold the inserts and manifold together.  Guess what, nobody in the world of Harley Davidson has ever seen this set up before, and I have checked with a lot of gurus.  Most say it is probably a one off system that was made maybe as a pro- to-type by someone who knew how to machine metal.  Like stock nipples the intake inserts are secured with pinged rivets that are a true nightmare to replace. Rather than drill out rivets and pull the inserts I am leaning to putting it all back together with new o rings and stainless steel bands, test for leaks, and go on with life.  What talent to create something like this from scratch, I am ecstatic when I make a bracket out of aluminum.......
« Last Edit: December 30, 2025, 11:35:25 AM by britman »
Offline Kevin
Re: Nipples
« Reply #1 on: December 30, 2025, 11:24:25 AM »
You had me at " Nipples" :-)
Like you, I can apppreciatte anyones ability to create a part out of a chunk of metal.
Even when I make a bracket it looks like a blind man did it....
I hope to have some time soon to work on my production skills.
With a little luck and a lot of time and $$$ my work might get to the level of a high school metal shop student .😀
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline dusterdude
Re: Nipples
« Reply #2 on: December 30, 2025, 02:00:05 PM »
My panhead is modded like that
Sent from my SM-S711U using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline willbird
Re: Nipples
« Reply #3 on: December 31, 2025, 09:46:54 AM »
From the perspective of a machinist who started out on purely manual machines I can say that the outer profile of that would of course be within the skillset of a tool and die maker or machinist but for a simple job those corner radii which are less than 90 degrees typically would not look that "nice". Milling the angles easy, cutting around the corner to blend the radius into the straight portions takes some fiddling around.
WAY easier on a cnc mill. That makes me think it was a produced and sold part maybe.
I'd way more expect the angles to me milled and the radii applied on say a belt or disk sander, still nice, very functional but way tougher to make it look perfect to the .001" using purely manual machines.
Today if I needed to do it I would use a rotary table on a Bridgeport..a guy making a mold for the part of course needs perfection, rather the customer is buying perfection.
Bill
Offline Dr. Frankenstein
Re: Nipples
« Reply #4 on: December 31, 2025, 03:51:20 PM »
Wow...! Those are Some Nipples...!
