Author Topic: 26 Rides in 2026. Frank's New Years Resolution that we can all enjoy.  (Read 21089 times)
0 Members and 15 Guests are viewing this topic.
« Reply #275 on: April 06, 2026, 06:27:06 PM »
Congratulations Terry.
Now if I can heal up from the bronchitis and sinus infection I've been hacking through this past week, I will get started here. I missed a couple of warmer days this past week. It's supposed to hit the 60s again later this week.
« Last Edit: April 07, 2026, 04:26:49 AM by newday777 »
« Reply #276 on: April 06, 2026, 09:31:12 PM »
Congratulations. Terry! The final on a good looking and running CB750 ;D
I'll hopefully get my first ride for 2026 this coming weekend.
Unless the weather apps change their minds and give us sh!t as they did this extended Easter weekend.
Offline Kevin D
  • SE Michigan
« Reply #277 on: April 07, 2026, 05:28:32 AM »
Well done Terry
Here is the first of your virtual awards
I will add the stage1 “First In” kit ASAP
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Kevin D
  • SE Michigan
« Reply #278 on: April 07, 2026, 05:46:37 AM »
There you go Mate
Congratulations and also Congratulations on your retirement
Leaderboard very soon
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #279 on: April 07, 2026, 06:02:20 AM »
Well done Terry! 4” of snow here overnight so not likely to catch up any time soon!
Offline Kevin D
  • SE Michigan
« Reply #280 on: April 07, 2026, 06:04:00 AM »
…..and a Leaderboard to be filled with your names
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #281 on: April 07, 2026, 06:23:10 AM »
Congratulations Terry!  Hope you get your back sorted and are back on the bikes quickly.
« Last Edit: April 07, 2026, 11:27:28 AM by BallAquatics »
Dennis...  70 SL175  71 SL100 (project)  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X https://motobike.us
« Reply #282 on: April 07, 2026, 06:36:50 AM »
Well it looks like it will be another week before I get to ride my 1st ride of 2026. Will have to wait for rain to clean the salt off the roads again.....
Offline Kevin D
  • SE Michigan
« Reply #283 on: April 07, 2026, 08:15:16 AM »
I rolled my CB from cold storage into its seasonal parking spot yesterday. I was going to try and start it and ride around the block a few times but while I was having lunch the sunny and temperate day turned to snow and sleet kaboshing my plans. Last night I was diverted to watch the UM basketball team complete their fine season and I hope and expect their academic record matches their athletic record.
 This morning I put my battery tester (thanks Per) on my 5 yr old AGM. The battery has sat quietly since the bike was run last November. Is 189CCA, 12.42v, 62% enough for the first start of 2026? I don’t know…. will find out later. I’ll not be riding today and although it’s nice and sunny the thermometer is at 26f, brrrr, and maybe it needs an overnight on the trickle.
Today is 4/7 and I need to get after my 1040.
My recent pursuits pictured below.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #284 on: April 07, 2026, 11:47:46 AM »
Kevin,
I should give that battery a charge,  a day or 2.
I check my bikes  batteries and car battery with that tester.
My car with short drives and alarm need a charge once a month.
My bikes  with new AGM  batteries 2026 more seldom, max every 2nd month. Maybe 3 months.
« Last Edit: April 07, 2026, 08:20:30 PM by PeWe »
« Reply #285 on: April 07, 2026, 03:51:52 PM »
Thanks guys, the K0 is running really well this year, and I thought it should be the bike to do ride #26 on. The weather yesterday was atrocious, so I sorted out some parts to take to the swap meet on Sunday and looked through the tub of parts that I’d brought home for my 1969 Kawasaki Mach III, but sadly there were only a couple of parts that will fit (Mach III’s are like K0’s, many differences between them and later models) but discovered some nice H1 parts that I’d forgotten about, that I’ll take to the swap meet.
I was slightly pissed off that a pair of headlight ears that I probably paid too much for weren’t Mach III’s items at all, and also discovered that one of the fork springs are missing, but found a minty H1 tail light assembly that will probably pay for the missing Mach III’s parts.
The sun has come back out again so I hope to do ride #27 today, on the XT660X. I’ll take my “26 Rides” tag over to the storage unit and put it on the K0, to add to the other 3 from previous years. Should be a good day. ;D
Offline Kevin D
  • SE Michigan
« Reply #286 on: April 08, 2026, 06:13:25 AM »
Kevin,
Yes, Per, the battery was on my charger overnight.
I tried to start it without charging, but was unsuccessful: the motor turned a few times at speed (but slowing) but did not fire. I will try again later today.
 It’s still cold and the 20w-50 is thick. My new Toyota uses 0w-16.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #287 on: April 08, 2026, 08:58:24 AM »
Kevin,
You did not test battery after the start attempt?
 If the health and charge has decreased much.
Offline Kevin D
  • SE Michigan
« Reply #288 on: April 08, 2026, 12:04:37 PM »
Kevin,
No Per, I didn’t put the meter on the battery afterwards. It failed to crank after a few spins. I went for the charger and it has been on for 20+ hrs. When I take the charger off I will let it rest for ?? Half hour?? and retest. I may yet circle the neighborhood today, temp is up to 53f.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #289 on: April 08, 2026, 12:54:43 PM »
04/08/2026 ride #15, 50+ miles on the Honda NC700X.  Had a doctors appointment and decided it was warm enough to go on the bike.  Blue sky's with temps in the mid 50'sF, just a light wind and plenty of sunshine.
Filled up on the way home and the bike's getting 76.64 mpg. The two cylinder half of a 1.5 liter Honda Fit engine just purrs along at 3000rpm running 60mph.
« Reply #290 on: April 08, 2026, 03:58:56 PM »
Kevin,
G’day Kevin, I have had batteries that, after charging read over 12 volts, but will either only crank an engine slowly, or won’t at all. Recently I saw a “cool tool” that not only measures the voltage, but also the cranking amps. Basically, you just input the CCA printed on your battery and the little gauge will tell you what cranking amps the battery is holding. I checked 4 batteries and two of them (fully charged) were holding way less than the rated CCA, so I threw them out. They’re a fantastic diagnostic tool, and mine cost less than $30 USD on Amazon. ;D
« Reply #291 on: April 08, 2026, 05:40:02 PM »
Kevin,
I bought a similar tester last July that works great. Best $30 tool.
Offline Kevin D
  • SE Michigan
« Reply #292 on: April 08, 2026, 07:05:47 PM »
Terry, that looks very similar to what I have, and yes, I have found it useful. I had hoped that the battery would rest all winter without charging and start my CB, it has done that before, but not this time at 5 years old.
 Today’s proceedings went much better after the battery was charged overnight.
First meter test was done immediately after removing the charger.
Second meter test 20 minutes later.
 Time for a load test: petcock open, key on, choke full, kill switch on, press starter button, and va-roooom on the first turn of the crank it fired! I eased the choke to 75%, turned the idle screw in a bit…..
I should have left the kill switch off to give the battery a workout and let the oil pump do its job…. But noooo, it’s running, first start of 2026, choke to 50%, idle to 1800rpm, get my jacket helmet gloves, and push it off the stand, woohoo it’s happening! I roll down the drive 1st gear, clutch in check rear brake roll again check front brake, neighbor waves, I’m grinning ear to ear, 2nd 3rd 25mph, stop sign at 6 mile, traffic clears and I’m off for real, 45 mph, stop at Farmington, right turn and a little more urgency through the gears oooh yeaaah,
Back through the sub, and roll into the garage, hit the kill switch still grinning, key off petcock off, put it on the center stand with a mighty pull/lift open the seat and take the third meter test.
5 miles… doesn’t count for ride #1… but it counts plenty :)
« Last Edit: Today at 04:28:39 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #293 on: April 08, 2026, 09:33:02 PM »
Excellent! Yeah I was surprised that after sitting for several months before my first ride in 2026 the 5(?) year old battery that hasn’t been near a battery charger fired the K0 up with no issues. I did give it about 10 kicks with the ignition off and fuel and choke on before I hit the starter button, but it fired right up and settled into a happy idle, while I put on my jacket, helmet and gloves, and rode it to fill it with fresh fuel, on my first ride for the year. They truly are wonderful old bikes!
I’m glad that I didn’t go for a ride today. The new seat cover for the XT660X was delivered today so I spent an hour or so removing the 2 seat covers from the spare seat, then I actually read the instructions on how to fit it, so stretched the cover over the seat and put it on the roof of the wife’s old Hyundai to soften the vinyl before stapling it in place.
I then remembered that my electric staple gun is pretty useless on bike seats so debated about taking it to the upholstery shop and getting them to fit it, but remembered how much I paid to have the VMax and “Venture Royale” seat recovered, looked at Amazon and found a Bosch upholstery stapler with 1000 staples (which should be enough..) for about $60 USD, and will wait until it’s delivered tomorrow, before I proceed any further.
I did go for ride #27 yesterday and thought about taking the VMax for a ride today but got sidetracked finding more bike parts to take to the swap meet on Sunday, and by the time I finished, the weather had turned for the worst, and it’s now raining again. I don’t really mind, this retirement gig is pretty good, if I have a crappy day today, there’s always tomorrow.. ;D
Offline Alan F.
Congrats on #26 Terry.
Offline Kelly E
  • Geriatric Hooligan
We picked up this pneumatic stapler for recovering seats for $30 at Harbour Freight. It uses T-50 staples and we've done several seats with it already.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
