Author Topic: gasket - goo or no?  (Read 424 times)
Offline crashmaster
  • 1972 CB 750 K2
gasket - goo or no?
« on: January 05, 2026, 03:47:48 PM »
I should know this by now. It's about whether any of these gaskets go on dry, or also get sealant on them (goo). I am pretty sure these are all dry (no goo). But here goes:
I already did the oil pan - so no goo there
I am still changing these 3-
1)Clutch cover gasket - goo or no? Have not pulled it yet to see if there is old goo
2)Transmission cover gasket - goo or no? Looks like it was dry
3)Stator cover gasket - goo or no? This was the kicker, as it has some silver/grey goo left behind from the previous gasket
Thanks for the help.
Offline denward17
Re: gasket - goo or no?
« Reply #1 on: January 05, 2026, 04:15:08 PM »
I say no goo on any of them....
Offline crashmaster
  • 1972 CB 750 K2
« Reply #2 on: January 05, 2026, 04:49:29 PM »
Den says no goo. Thanks Den!
Online jgger
« Reply #3 on: January 05, 2026, 05:26:43 PM »
If you feel the need for goo, put it on the side that touches the part you are removing. This holds it in place AND is much easier to clean off at the bench. As always, use it sparingly  if you use it at all.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: January 05, 2026, 05:30:44 PM »
No goo!  They didn't have it from the factory and honda bikes are very fluid tight.
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #5 on: January 05, 2026, 05:35:11 PM »
Clean flat mating surfaces are a must!
Offline crashmaster
  • 1972 CB 750 K2
« Reply #6 on: January 05, 2026, 06:13:14 PM »
Thanks!
« Reply #7 on: January 06, 2026, 12:06:39 AM »
On paper gaskets NOT THE HEAD you can use CLEAN grease to help them stick to a joint surface without making them a swine to clean off next time
Offline Cevan
« Reply #8 on: January 06, 2026, 05:50:38 AM »
I use a little Curil T on paper gaskets.
1972 CB500/4
1974 CT70
« Reply #9 on: January 06, 2026, 07:09:26 AM »
I have an ancient aerosol can of a FelPro spray on gasket glue. It sprays out a fine mist of red adhesive. For side covers I usually give a VERY LIGHT spray to the cover side of the gasket and slightly oil the engine face before installation. Don’t over torque and the gaskets can last virtually forever…..
« Reply #10 on: January 06, 2026, 09:21:05 AM »
  I use a little rub of chap stick on the side that I'd like to come off later. Sometimes if I feel the need to stick it in place, a coat of aerosol copper coat on the cover side.
Offline rotortiller
« Reply #11 on: January 06, 2026, 12:22:09 PM »
Say no to 'Gorilla Snot'.   :)
Offline pickleknuckles
« Reply #12 on: January 06, 2026, 12:25:00 PM »
No goo imo and if you're worried about leaks and have everything reasonably well cleaned up, soak the gasket in oil or whatever fluid it comes in contact with and let it swell up a bit before installing.
Sent from my Pixel 8 Pro using Tapatalk
Offline crashmaster
  • 1972 CB 750 K2
« Reply #13 on: January 06, 2026, 04:04:29 PM »
good goo info - thanks all
