Author Topic: Old dream coming back: oil hoses?  (Read 1783 times)
« on: January 07, 2026, 10:13:50 PM »
After buying lots of hose(s) that isn't the right stuff, and researching the 2 different types of hose that Honda used in the 750, and cutting up a bunch of old ones to figure out why some last(ed) 50 years while others lasted 15 years or less, I've figured this much out:
1. In the early 750 the hoses were unlined. They were just AN10-size rubber (fabric-covered) hose over AN6-size pipe fittings, with custom-made ends to fit the bike. I have even seen some very early sandcasts that didn't have the fabric cover, and they were SAID to be original hoses.
The FLOW SIZE is set for AN6 hose ID, so anything that size or larger will meet the engine's flow needs. We've seen this proven out in choppers and various racebikes over the years: many of the oil coolers use AN6 (some Lockharts used even smaller ID) hoses with no ill results.
2. In the 750K5 (and probably during the late 750K4) the hoses became lined-type hoses, ID size being otherwise the same: this is when they started cracking (after 10 years) right where the line turns a little bit on the rear (inner) hose where it exits the tank. This hose gets bent upward slightly, just ahead of the tank's connector, after it is bolted into the engine: the (stiffened from age & heat) liner doesn't appreciate that very much, stress cracking after a time - these are the most common leaks we hear about. This is the oil supply line to the engine, and air leaks here can cause low oil PSI when the oil is cold. I have only seen one bike that outright refused to prime the engine's oil pump, even though the engine had run in my test stand first (different oil tank), when this inner hose would weep when hot - so I know it can be an issue.
3. In the later K2 (and likely until the K4-5 change) there are SOME hoses with smooth liners inside and some with just the normal rubber finish inside. I suspect, from knowing the other 'experiments' that came out of the New Factory (2nd factory) for this bike, that the lined hoses appeared in the New Factory bikes, but not in the Old Factory bikes. This means that most of the bikes made before 4/1972 production did not have the lined hoses, because the 'New Factory' opened somewhere around that time. This corresponds to my notes, which showed that the K4 and later bikes seemed to be the ones that had the weepy hoses the most often, with those last log entries being circa 2001. Today it can be hard to tell if a given bike has original hoses or not, but the lined hoses are the ones in my collection that leak.
So...I'm going to find some unlined AN10 hose with no steel braid in it, nor over it, which should fit the collars after crimping a standard AN10 ring onto the AN10-size, non-stainless-overbraided, non-inner-lined, smooth rubber ID hose over the Honda fittings. I have a set of fittings from a 750K3, which should fit my K2 fine. They are different (return hose length, angles) from the 750F0 forward: it might be a while before I can make a set of those, as I have no F0+ bikes here to test with.
I'm hoping to beat the $200+ cost of buying a set from Japan. Mine are bleached to almost white now, and their fabric jackets are frayed from all the out-in trips (3) my engine has experienced . The chrome-braided hoses are always too thick (especially for the F0 and later bikes), using up every available mm when installing them, which frequently causes their early failure for lack of wiggle room with temperature. I have seen more of those chrome-covered ones leaking than any others, and have installed 2 sets, swearing that kind of work off forever after the last set from Crapy on a custom cafe' I built some 10 years ago. I ended up shaving off the side of that one's engine (right side) with a half-round file and cut off the chrome mesh behind the frame member the hose was bent around in order to get a straight-enough path for the supply line on that 750K5.  >:(
Offline newday777
Re: Old dream coming back: oil hoses?
« Reply #1 on: January 08, 2026, 01:18:48 AM »
Interesting observations Mark. I'll have to keep a closer eye out for the leaks as I go through my bikes for leaking hoses.
Do the Fs and the K7/K8 use the same oil lines or just the fittings? I'll take a look at the parts fiche for the part numbers on them. (Hmmmm. I might have an extra set of hoses from a F3 and a K8 from those 2 parts bikes I've pulled apart???)
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #2 on: January 08, 2026, 01:40:10 AM »
So the fiches show that all the Fs, F0-F3 and the K7/K8 all use the same hose part numbers A and B,  and, that they also use hose A, sharing the same part numbers as the 69-76 K models all had.
First picture is the Fs and K7/K8 hose part numbers.
Second picture is K6 fiche hose part numbers.
Third and forth pictures are the K0-K2(CMSL) fiche numbers using the original hose A part numbers of 15510-300-007 (superceded to 15510-300-017, the same as K3-K8, F0-F3)
« Last Edit: January 08, 2026, 01:49:38 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline 69cb750
« Reply #3 on: January 08, 2026, 03:48:54 AM »
Mark,
Great research, thanks for posting.
I always prefer exchanging federal reserve notes for nice parts.
Making parts is work.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: January 08, 2026, 07:01:05 AM »
I have about 8-9 old hoses in a bag. I will be having a much closer look, next time I spill them out!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: January 08, 2026, 07:10:05 AM »
I have one set that I'd like to "re-hose". Am I reading that at some point you might be able to do them?
Great observations, as usual, thank you for the information.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #6 on: January 08, 2026, 07:59:46 AM »
Mark, good chance I have a "spare" F0 hose in the cave. However, I am maybe 3000 miles away and won't be back until the last spring snows arrive.
« Reply #7 on: January 08, 2026, 08:41:37 AM »
When one of my K1 hoses started weeping, I replace it with some vacuum hose, which comes in 1/32" increments, from an auto parts store. It's still holding after 20+ years. :)
« Reply #8 on: January 08, 2026, 08:51:38 AM »
We really need someone to start making them again, I have these on my bikes...
« Reply #9 on: January 08, 2026, 10:42:13 AM »
Yep, that's how it went: I have accidentally tried to install a later hose (I call them the "F" hoses ;) ) on a K4 I resto'd some time ago, which taught me about the change. I hadn't paid attention to it before that. I've also accidentally found that making the "B" hose about 2mm longer in the later bikes also makes them last much longer because they don't have to be tugged on to make them reach (or else the mounting holes in the oil tank have to be ovalled a tad, rear top one vertically and the front one horizontally) to make the "A" hose fit more easily. This "accident" came about when I bought some aftermarket-made hoses from some long-gone chopper-parts shop that had the pretty chrome cover, and they were longer by about 1/8" inch. This made the outer one bulge away from the frame, causing an ugly look for the otherwise nicely-done custom bike, and made the rider's heel bump into it.
Since the F0 bikes were (rumored to be) way over their development budget, I have [since that mis-fitting event] long suspected that making a 2mm longer "A" hose for the F0/1 (and maybe the F2/3 and K7/8) could be a good thing? Without having that stress on them, they will last longer: the only "A" hoses I've seen leak came from F0/1 bikes. I have one of those "pairs" in my shed, marked "F0/1 leakers". The fabric lace cover of the "B" hose looks like the hose was pulled on, the lacey pattern being skewed the long way as witness. Before I get this sorted out, I'll be looking for an F0/1 bike to try a pair on (I only have K bikes on hand right now, sold my last F1 long ago).
« Last Edit: January 08, 2026, 10:44:32 AM by HondaMan »
« Reply #10 on: January 08, 2026, 10:48:47 AM »
Ultimately, yes: I bought the crimping tool (expensive bugger) some 8 years ago or so, and the collars, a whole box of them. Then I ran into the wrong size OD of hose from 3 vendors so far, am trying to sort that issue out now. I have about 30 feet of wrong hoses, at about $8-10 per foot from local shops. :(
It appears Porsche uses the right hose in some of their cars: their dealerships sell it by the foot at some Porsche-like prices.  :o
« Reply #11 on: January 08, 2026, 10:51:54 AM »
I think you mentioned this before, and I went to some local auto parts stores and found some hose that sounds like yours. It fits right, but just isn't so "pretty" like Honda wanted them to be. Heck, if there was a good way to paint them, candy-colored hoses to match the side covers could be cool? :D
Offline newday777
« Reply #12 on: January 08, 2026, 10:59:42 AM »
PM sent on possible hose
Stu
My current rides
Prior bikes....
« Reply #13 on: January 08, 2026, 11:00:19 AM »
Except for the crimp ring on yours, those look a lot like the "too long" ones I ran into from a custom shop (mentioned above) some time ago. The ones I got then had the correct-looking crimp ring (8-position tooth imprints) and that pretty chrome overbraid, which went well with all the other chrome things on that custom: the outer one was simply too long and would stand out from the frame no matter how it was twisted, so the 2 hoses weren't parallel like Honda intended. It's interesting how such a small matter as non-parallel hoses made a quickly-noticed appearance "flaw" on the side of that otherwise very nicely done bike.
The hoses I currently have with overbraids also have steel reinforcement mesh in their layers, totally unneeded in this setup. That causes their OD to be thicker than AN spec, too, so they fit poorly in the frame - especially the inner one. It seems the local hydraulic shops only stock that type because of their pressure needs, so I have to find the hose online somewhere.
« Reply #14 on: January 08, 2026, 12:54:29 PM »
Long time ago i worked on backhoes and 360 machines for our water authority and i remember hydraulic hose was speced as bore then either 1 wire, 2 wire, or 3 wire which i believe was to do with the reinforcing in the rubber to hold the pressure, we also had "reusable" hand fit fittings where you had ro carefully remove the outer rubber and screw the outer of the fitting over the reinforcing(lh thread) then the inner part of the fitting had a long cone that went inside the pipe and the unit screwed into the outer with a rh thread making a very tight fit
Offline newday777
« Reply #15 on: January 08, 2026, 01:40:58 PM »
I was just reading through my fb and saw this 78 F near you in Bloomfield for $1300
Stu
My current rides
Prior bikes....
« Reply #16 on: January 08, 2026, 03:40:54 PM »
Yep, those were the 'rules' for hydraulic hoses before ISO. No-wire, or 1/2/3 reinforcement strands in the first reinforcement layer, and an optional top web or various materials. I used it a lot in the oilfield circa 1980s decade, so when I started with this little project I thought I knew the 'ropes' (strands?) already. That's how I ended up with so many wrong hoses, ordering them online or by phone, using my "old" valid methods. I didn't even know ISO changed it all before the century rolled over. :(
I don't like having to learn it all over again, makes me feel like all that work back then went to waste!  >:(
« Reply #17 on: January 08, 2026, 03:41:25 PM »
Boy, that's someone's nice last-century tourer!
Offline willbird
« Reply #18 on: January 10, 2026, 05:47:24 AM »
So if one is not trying for OEM authintic is there anything wrong with the Andrews Motorsports billet AN fitting devices ??
eBay item number:183728308579
No affiliation on my part.....have gazed fondly at them a few times
Offline crashmaster
  • 1972 CB 750 K2
« Reply #19 on: January 10, 2026, 07:44:53 AM »
Great info - thanks for sharing!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #20 on: January 10, 2026, 08:00:54 AM »
Now I'm getting confused. Original hoses were not covered in stainless braid, right? They had the cloth covering that was sort of black?
Be nice to get a set for the dark stock look.
1973 CB 750 K3
« Reply #21 on: January 10, 2026, 08:08:18 AM »
Correct, the stock hoses had a black fabric braided cover. Also, there is Zero pressure in these hoses, other than the weight of the oil in the tank, so high pressure hose is not needed.
« Reply #22 on: January 10, 2026, 06:23:22 PM »
I've always wondered how those would even fit on a stock CB750K0-K6 or even the ones up through 1978? They require a nut be installed on the end of the hose to screw onto those fittings, which will add considerable spacing outward from the engine, interfering with the footpeg (and likely the frame).
I suspect they are for another CB750, possibly not the SOHC4 bikes, although I don't remember any later ones with an oil tank: I think all the later ones are wet-sumpers? Could be wrong about that: I'm a CB750 SOHC4 snob...
Offline BenelliSEI
  • 1969 cb750
« Reply #23 on: January 11, 2026, 05:49:34 PM »
All the Aeroquip hoses we use on the race car still work that way today.
Offline willbird
« Reply #24 on: January 13, 2026, 06:47:32 AM »
Somewhere in a box I have a race car building book that describes the two types of fittings in use at that time, one was a cutting type that preserved the lining and the other type worked some other way. I put the Earls econobraid on my CB750K2 when I redid it, the  ends look like a hex but just hide a hose clamp. I re used the original barb fittings after cutting away the crimp. I called a hydraulic shop and they were "sure come on over" then once they figuired out it was for an on road MC they freaked out and told me "nope we are not selling you anything". Lesson learned, from then on it was some kind of race only machine I needed stuff for.
Well made drop in crimped hoses would be a really cool thing :-).
Bill
Online Don R
« Reply #25 on: January 14, 2026, 09:29:20 AM »
 I think the Andrews fittings are designed to use our engines in a mini sprint car.
Offline willbird
« Reply #26 on: January 14, 2026, 03:30:58 PM »
OK, seems that is what they seem to focus on. Could be good for an engine test stand though to allow running the engine prior to putting in frame and maybe re torque head gasket.
Bill
« Reply #27 on: January 14, 2026, 04:59:58 PM »
So, Hondaman, are you going to become our source for oil and brake hoses? At the very least, we know you will not abandon it and can count on you.
« Reply #28 on: January 14, 2026, 07:15:26 PM »
When I can find the right hose, I plan on making a 'refurb' sort of operation where I can copy the ones sent to me. I would like to come up with a hose-bend-former, too, because this would, like Honda's own hoses, provide extended life for them. While the outer one isn't much stressed with its gently radius, they seem to always leak at the tank, just like the inner ones do, from being bent a bit right there.
At this moment I'm fighting a 2-front battle: my wife is about to go into surgery that we hope will solve a 3-year-long serious trouble, which is limiting my research time. The other "front" is in finding the right hose for this, with the black lace covering. I don't want to make some cheap Chinese crap hoses that will die in 2-3 years - I've already found Chinese and Vietnamese (same thing) hose that looks correct, but won't be, long term. While Gates Hose is one of my favorites for long-lasting hose, so far I haven't located any form of those with the weave covering except hydraulic hoses, which won't work. They are too stiff from their embedded steel mesh, which over time will cause the collars to distort and then lose their grip on the hose itself - because of the bends we have. Without those bends, they would last a lifetime, if they would fit through the passages: on the K0 and early (Old Factory) K1 bikes they (thicker hoses) don't fit very well. The last time I tried some aftermarket hose with the chrome cover on a K1 (Old Factory) bike, it was very difficult to get the lower front connector into the engine: the bolts also would not align without adding another bend in the hose at the connector: this will all cause it to fail in the hose, at the connector. I (we) don't need that kind of garbage. That particular bike was a show-custom-cafe' bike, destined more for storage than use, so I think it will be OK.
For example: I haven't been able to continue searching since last week Monday because of this medical thing. It will happen, just not on my schedule (which was almost 8 years ago, when I bought the expensive crimping tools for it...).
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #30 on: January 21, 2026, 07:27:50 AM »
All the best with both "fronts" to you. Thank you for your hard work and expertise.
1973 CB 750 K3
« Reply #31 on: January 31, 2026, 05:32:41 PM »
Well, I think I have a usable hose: it still has a slight weave of steel fibers in it, but the dimensions are very close to the OEM version (1969-1973) that lacks the plastic liner (which always cracks right next to the tank on the supply hose). Here's a pic of the $300 (!) crimper I got for them, with the parts and a chunk of the AN-10 size "lightweight" hose (aircraft fuel line hose in this case). I have some crimp rings, will try to copy a hose set for the pre-plastic-lined K bikes' hoses this weekend.
What I've discovered on this journey is: while the "AN" hose sizes were created circa WWII and conformed to the dimensions as they are named, this all stopped when DIN/ISO was adopted in the world manufacturing convention(s) circa 1996 - at least, as far as "AN hose size" is concerned. This seems to be why their has been so much confusion about them for so long. As one example: the pretty chrome-covered ones we see so often for sale have an ID that is OK (close to 10/16", the AN convention) but the OD is slightly oversize for the hose body. This makes them come up slightly shorter upon installation, which I've noticed on several bikes I've worked on that had those: the outer (return) hose was a tight stretch on those bikes. It should have been made a few mm longer to make up for the way it contracts when bent with the rigid inner steel weave, and the supply hose doesn't like to make the bends for the same reason. Japan used the international AN hose sizes and construction rules for making the hoses (at least the early ones before the inner-lined versions after 1973), which were essentially (1/16" x [AN number]) ID, and the OD was irrelevant so long as the layers of the hose being constructed suited the task at hand.
So, the one big difference today seems to be that all the makers of this sort of "AN" hose ALL have at least one layer of steel weave in the hose stack, regardless of the hose's purpose. In the end this means these new hoses will be slightly longer in order to fit well (on the order of 3mm for the supply hose and 4-5mm for the return hose) so that the connectors will fit straight into their holes like Honda's versions always did: no pulling or stretching required.
Next: finding the best way to cut this stuff...
Then come the later supply hose, and see if the lack of the inner lining that cracks at the supply line's fitting crimp (because it has to be pulled forward to install) will solve that little weepy problem long-term. That one is longer.
« Last Edit: January 31, 2026, 06:01:01 PM by HondaMan »
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: February 04, 2026, 01:42:05 PM »
I put a few wraps of masking tape on all the hoses I use and cut them with a fine tooth band saw (or hacksaw at the track). That crimping machine looks the part!
Offline BenelliSEI
  • 1969 cb750
« Reply #33 on: February 04, 2026, 01:45:40 PM »
Mark….. I have a bag full of old hoses. Will count them up tomorrow. Are you going to start making new hoses? I can cut the old hoses off and send you all the ends?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #34 on: February 05, 2026, 07:22:44 AM »
I too have a set of ends I can send if you start up.
1973 CB 750 K3
Offline BenelliSEI
  • 1969 cb750
« Reply #35 on: February 05, 2026, 07:51:42 AM »
Want these? I'll cut off the hoses and send them?
« Reply #36 on: February 05, 2026, 08:42:25 AM »
I am 'stalled' this week (and most of next, probably) on these hoses by my wife just having surgery Monday: I'm playing caretaker and cooking for her (hoping that won't kill her and put me in jail?) and taking care of the pups. I only get about an hour a day to work on "stuff" this week, and most of that is going to the Black Bomber I'm trying to get back to Bob Kelly of VJMC. It's almost running. The starter clutch roller(s) are being a real problem from 35 years of sitting with old oil in the engine, so one of them got rusty. :(
I have 2 pairs of "ends", one from an F1 and the other from a K4. So, I have both types, at least, for my first go at it. I just got the sample of AN10 hose that will fit, and will order some more of that over the weekend. I'll make the first pair and install them on my K2 to test fit-up.
Offline BenelliSEI
  • 1969 cb750
« Reply #37 on: February 05, 2026, 11:49:24 AM »
Just let us know if you want more ends. I have no use for this stash!
