Author Topic: Old dream coming back: oil hoses?  (Read 14225 times)
Re: Old dream coming back: oil hoses?
« Reply #25 on: January 14, 2026, 09:29:20 AM »
 I think the Andrews fittings are designed to use our engines in a mini sprint car.
Offline willbird
« Reply #26 on: January 14, 2026, 03:30:58 PM »
OK, seems that is what they seem to focus on. Could be good for an engine test stand though to allow running the engine prior to putting in frame and maybe re torque head gasket.
Bill
« Reply #27 on: January 14, 2026, 04:59:58 PM »
So, Hondaman, are you going to become our source for oil and brake hoses? At the very least, we know you will not abandon it and can count on you.
« Reply #28 on: January 14, 2026, 07:15:26 PM »
When I can find the right hose, I plan on making a 'refurb' sort of operation where I can copy the ones sent to me. I would like to come up with a hose-bend-former, too, because this would, like Honda's own hoses, provide extended life for them. While the outer one isn't much stressed with its gently radius, they seem to always leak at the tank, just like the inner ones do, from being bent a bit right there.
At this moment I'm fighting a 2-front battle: my wife is about to go into surgery that we hope will solve a 3-year-long serious trouble, which is limiting my research time. The other "front" is in finding the right hose for this, with the black lace covering. I don't want to make some cheap Chinese crap hoses that will die in 2-3 years - I've already found Chinese and Vietnamese (same thing) hose that looks correct, but won't be, long term. While Gates Hose is one of my favorites for long-lasting hose, so far I haven't located any form of those with the weave covering except hydraulic hoses, which won't work. They are too stiff from their embedded steel mesh, which over time will cause the collars to distort and then lose their grip on the hose itself - because of the bends we have. Without those bends, they would last a lifetime, if they would fit through the passages: on the K0 and early (Old Factory) K1 bikes they (thicker hoses) don't fit very well. The last time I tried some aftermarket hose with the chrome cover on a K1 (Old Factory) bike, it was very difficult to get the lower front connector into the engine: the bolts also would not align without adding another bend in the hose at the connector: this will all cause it to fail in the hose, at the connector. I (we) don't need that kind of garbage. That particular bike was a show-custom-cafe' bike, destined more for storage than use, so I think it will be OK.
For example: I haven't been able to continue searching since last week Monday because of this medical thing. It will happen, just not on my schedule (which was almost 8 years ago, when I bought the expensive crimping tools for it...).
« Reply #30 on: January 21, 2026, 07:27:50 AM »
All the best with both "fronts" to you. Thank you for your hard work and expertise.
« Reply #31 on: January 31, 2026, 05:32:41 PM »
Well, I think I have a usable hose: it still has a slight weave of steel fibers in it, but the dimensions are very close to the OEM version (1969-1973) that lacks the plastic liner (which always cracks right next to the tank on the supply hose). Here's a pic of the $300 (!) crimper I got for them, with the parts and a chunk of the AN-10 size "lightweight" hose (aircraft fuel line hose in this case). I have some crimp rings, will try to copy a hose set for the pre-plastic-lined K bikes' hoses this weekend.
What I've discovered on this journey is: while the "AN" hose sizes were created circa WWII and conformed to the dimensions as they are named, this all stopped when DIN/ISO was adopted in the world manufacturing convention(s) circa 1996 - at least, as far as "AN hose size" is concerned. This seems to be why there has been so much confusion about them for so long. As one example: the pretty chrome-covered ones we see so often for sale have an ID that is OK (close to 10/16", the AN convention) but the OD is slightly oversize for the hose body. This makes them come up slightly shorter upon installation, which I've noticed on several bikes I've worked on that had those: the outer (return) hose was a tight stretch on those bikes. It should have been made a few mm longer to make up for the way it contracts when bent with the rigid inner steel weave, and the supply hose doesn't like to make the bends for the same reason. Japan used the international AN hose sizes and construction rules for making the hoses (at least the early ones before the inner-lined versions after 1973), which were essentially (1/16" x [AN number]) ID, and the OD was irrelevant so long as the layers of the hose being constructed suited the task at hand.
So, the one big difference today seems to be that all the makers of this sort of "AN" hose ALL have at least one layer of steel weave in the hose stack, regardless of the hose's purpose. In the end this means these new hoses will be slightly longer in order to fit well (on the order of 3mm for the supply hose and 4-5mm for the return hose) so that the connectors will fit straight into their holes like Honda's versions always did: no pulling or stretching required.
Next: finding the best way to cut this stuff...
Then come the later supply hose, and see if the lack of the inner lining that cracks at the supply line's fitting crimp (because it has to be pulled forward to install) will solve that little weepy problem long-term. That one is longer.
« Last Edit: March 19, 2026, 09:48:07 AM by HondaMan »
« Reply #32 on: February 04, 2026, 01:42:05 PM »
I put a few wraps of masking tape on all the hoses I use and cut them with a fine tooth band saw (or hacksaw at the track). That crimping machine looks the part!
« Reply #33 on: February 04, 2026, 01:45:40 PM »
Mark….. I have a bag full of old hoses. Will count them up tomorrow. Are you going to start making new hoses? I can cut the old hoses off and send you all the ends?
« Reply #34 on: February 05, 2026, 07:22:44 AM »
I too have a set of ends I can send if you start up.
« Reply #35 on: February 05, 2026, 07:51:42 AM »
Want these? I'll cut off the hoses and send them?
« Reply #36 on: February 05, 2026, 08:42:25 AM »
I am 'stalled' this week (and most of next, probably) on these hoses by my wife just having surgery Monday: I'm playing caretaker and cooking for her (hoping that won't kill her and put me in jail?) and taking care of the pups. I only get about an hour a day to work on "stuff" this week, and most of that is going to the Black Bomber I'm trying to get back to Bob Kelly of VJMC. It's almost running. The starter clutch roller(s) are being a real problem from 35 years of sitting with old oil in the engine, so one of them got rusty. :(
I have 2 pairs of "ends", one from an F1 and the other from a K4. So, I have both types, at least, for my first go at it. I just got the sample of AN10 hose that will fit, and will order some more of that over the weekend. I'll make the first pair and install them on my K2 to test fit-up.
« Reply #37 on: February 05, 2026, 11:49:24 AM »
Just let us know if you want more ends. I have no use for this stash!
« Reply #38 on: March 17, 2026, 08:25:59 PM »
Well, after many doctor visits and failed post uploads...
I'm back with attempting the hoses again, starting with the Supply hose from a 750K2. It doesn't have the plastic liners inside that appeared around the time of the K4 bikes.
« Reply #39 on: March 17, 2026, 08:35:51 PM »
The first hose shows the different crimp pattern of this Air Conditioning Crimper set made for AN hose. I've discovered that if I use AC hose (very thick sheath, multiple layers of steel fibers) then the AN10-size crimp jaws work, but with this thinner non-pressure type hose I have (airplane fuel line) in AN10 size, I have to use the AN8 crimp tooling, or else it barely crimps at all. I think the length of the end fittings inside the hose will seal even without a crimp, but that would also let the fitting be twisted inside the hose, which could, with heat cycling over enough time, weaken the integrity of the crimp's seal. So, I'm using the AN8 crimp bits on this hose (and will also on the "naked" hose I have in AN10 size, which has no braided cover nor steel weave layer). That hose might be like Scottly's hose?
BenneliSEI: yes! I would like those hoses, but intact: I've discovered that I have 3 supply hoses, and all 3 differ in hose length a little bit. I'm not sure 'why' yet? PM me about details when you have time.
« Last Edit: March 25, 2026, 09:25:06 AM by HondaMan »
« Reply #40 on: March 18, 2026, 05:53:37 AM »
Missed this post until today. Sending PM now.
« Reply #41 on: March 19, 2026, 08:19:45 AM »
Mark…. Sent the hoses this am. We’ll see how Canada and US Post do! Cheers, John D.
« Last Edit: March 26, 2026, 09:57:01 AM by BenelliSEI »
« Reply #42 on: March 19, 2026, 09:08:09 AM »
I also have a set of hoses I'd like to like to send so I end up with a spare set.
I'll look for them and get them ready to go.
« Reply #43 on: March 22, 2026, 03:04:30 PM »
Many thanks! They will probably 'star' in pictures here pretty soon. I made up the first supply hose, am working on the first return hose next. When I get out of the nursing stage (for my wife, following surgery) I'm going to try these out on the K4 in the shed.
Somewhere along the way I need someone with an "F" or K7/8 bike to try out the return hose for them. It has the longer neck on the engine's fitting, and the hose is a different length.
« Reply #44 on: March 25, 2026, 05:16:22 AM »
I noticed some variations in the hose lengths I sent you. I’ve built a few K7/8’s so you may have those hoses in there too.
« Reply #45 on: March 25, 2026, 09:36:41 AM »
I do wonder about the varying lengths on these hoses, as all that changed in Honda's part number history is the vendor (the last 3 digit of the part number, upper 2 digits, indicate various vendors). I suspect they (2nd generation Parts Designers) were adopting varying lengths not knowing what the effect might be, as they hadn't actually designed the 750. It's that old "sandcast crew lore" thing all over again.
On the return hose the extra length up to +3mm shouldn't hurt anything, and I have 2 of those K7-era hoses, both of different length by a couple of mm. It's the inner supply hose that has me scratching my head: the early ones were molded into the S-bend shape where it exits the tank while 100% of the ones I've seen that were bought as Parts were just straight hoses. The lined ones (that appeared in the K4 bikes) then crack right where this 'wiggle' has to happen to get over the rear top engine bolster before it then swoops down to the oil port on the engine. I know of at least one rider who installed a spring inside the supply hose of his 750 roadracer because the engine had been out so many times he had spare hoses on hand for damaging them so often. When he put the spring in, it stopped hurting the hose when it was removed with the tank. Seems like a good idea for frequently removed hoses, and maybe also for these straight hoses that will have to make the S-bend upon reinstallation? I might try that, too.
« Reply #46 on: March 25, 2026, 09:51:03 AM »
Maybe the "s" was just the result of heating and cooling in place? Or were they shaped by the factory?
« Reply #47 on: March 25, 2026, 10:13:01 AM »
I'm not sure, except for just one occasion: in 1971 we got a damaged 750K1 (hit by a car on the right side) and had to replace the sidecover(s), oil tank and hoses, along with some other minor things. The new hoses we got came in a large, flat cardboard Honda parts box (each) and when pulled out of the box had the same wiggly shape as the hoses we took off the bike. I remember wondering about how much work Honda had put into those parts (and boxes and plastic wrap and plugs in the end fittings) for the small amount of $$ we had paid for them. At the time I was still enrolled and in training for Apollo 18 (which I was selected to work on in 1966, entering a special "tract" of schooling after that) and was already 'touchy' about extra-cost things that had to happen with parts made for those spacecraft. I tried to estimate how much those end plugs (plastic), plastic wrap, and specially-shaped-and-printed boxes had cost?
Offline Oly
« Reply #48 on: March 25, 2026, 02:12:31 PM »
Here a picture of the original hoses off my K1 manufactured 8/70 for reference.
They defiantly look factory shaped to me.
1971 CB750 K1
1967 BSA 441 Victor
1966 Yamaha 250cc YDS3c Big Bear Scrambler
« Reply #49 on: March 25, 2026, 04:26:37 PM »
Interesting. I have some that came with a parts lot I bought and the new ones from CMSL come in long boxes and are “straight”.
