Author Topic: 1975 CB550 Front End Clunk Sound  (Read 63 times)
Offline CB750wannabe
« on: January 17, 2026, 02:39:09 PM »
I'm hearing a "clunk" sound when I hit any bumps.  It sounds like it's coming from near the steering stem but I know it can be difficult to know exactly where it's coming from.  I replaced the steering bearings but that wasn't it.  Any ideas?  Thanks in advance! I don't think the forks have ever been rebuilt.
1971 CB750K Candy Garnet Brown
http://forums.sohc4.net/gallery/28485-110112203145.jpeg
1975 CB550 K1 Candy Jade Green
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: 1975 CB550 Front End Clunk Sound
« Reply #1 on: January 17, 2026, 04:46:47 PM »
Is the fluid level correct and the proper viscosity in the forks?
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #2 on: January 17, 2026, 05:10:35 PM »
You may laugh, but I chased the  same kind of noise on my cb750K8 many years ago. Try a zip tie on the speedo cable to the fender loop and the fender stay. Cured my “thunk”. I had a heavy cable and it was whacking the fender stay loud enough I could hear it! Adjusted the speedo gear up a little higher and that cured it.
Offline denward17
« Reply #3 on: January 17, 2026, 09:13:37 PM »
Did you install the All Balls tapered bearings?
If so you likely have increased the space above/below the fork ears, allowing them to move up/down easily, thus making a thumping noise.
