Author Topic: remove forks 1972 CB750K2 help  (Read 80 times)
Offline crashmaster
  • 1972 CB 750 K2
« on: January 18, 2026, 04:40:42 PM »
I am having trouble removing the forks from the triple tree. I want to change the gaiters and remove/derust the headlight brackets. I have the 2 sets of clamps loose. I also see there is an allen bolt in the very bottom of the forks (inside). Do I mess with that? Or does that just connect the upper and lower fork halves? See attached pics
My next move was to tap a similar size socket on top of the fork tube at the triple tree to try to free it up/get it started. Or put the caps back on the forks first and tap them with a dead blow mallet. Thought I better ask first in case I am missing something. Thanks
« Last Edit: January 18, 2026, 04:43:46 PM by crashmaster »
Online kyle750
Re: remove forks 1972 CB750K2 help
« Reply #1 on: January 18, 2026, 05:10:37 PM »
I just finished redoing my front forks on my K1 and installed new fork ears, bushings, fork seals, and gaiters. Fortunately both of the forks came out easily.  I sprayed WD-40 around the triple tree and around the rubber bushings and placed a piece of wood on top of the fork tube bolts and hit them firmly with a hammer. I hit all my old bolts with a hammer hoping the blow loosens up the rust.  Then grabbed each fork tube firmly while twisting and pulling down and out. Took some force and wiggling but they slid out.  If the tubes are rusted at the triple tree clamps you might try carefully prying open the vertical cut with a screwdriver and then try to get more WD-40 inside.
Late Edit:  I also wore thick heavy duty rubber gloves when pulling out the forks.  The tubes are slippery and the grip on the gloves really helped with the twisting and pulling.
« Last Edit: January 18, 2026, 06:39:38 PM by kyle750 »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: January 18, 2026, 05:11:13 PM »
With the two different metals the corrosion can be quite cumbersome.
Take the clamp bolts all the way out.
Apply some penetrating oil.
Use a hard plastic wedge to slightly spread the clamp.
Start by twisting  the fork tube to break it free.
Keep twisting and pulling downward.
The bolt on the bottom only needs to be removed if you are rebuilding the forks.
As above if you need to use a mallet
 . Put the caps back in and tap down.
« Last Edit: January 18, 2026, 05:13:24 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
Online bryanj
« Reply #3 on: January 18, 2026, 05:22:02 PM »
All pinch bolts all the way out
GENTLY pry apart the gap in the trees pull fork down, it will be tight and corroded.
DO NOT undo the allen bolt unless you are replacing seals, and it wont undo with springs and top nut out anyway
Offline crashmaster
  • 1972 CB 750 K2
« Reply #4 on: January 18, 2026, 07:04:58 PM »
Hey thanks, guys. Got em out!
Is it smart to replace the seals while it is apart? When draining the left fork oil, the first couple squirts looked very clear/ waterish before oil came later. The right side looked like oil from the start.
Online kyle750
« Reply #5 on: January 18, 2026, 07:40:57 PM »
Yes.  Fork seals are inexpensive.  Easy to replace while the forks are out - better now than later.    My old fork oil was black and thick like road tar and smelled awful.
Offline crashmaster
  • 1972 CB 750 K2
« Reply #6 on: January 18, 2026, 08:44:03 PM »
thanks, Kyle. The allen bolts seemed super tight. Any advice on releasing them? Any other parts in there that need updating? Thanks again
Online kyle750
« Reply #7 on: January 18, 2026, 11:12:59 PM »
The fork damper allen bolts were torqued in tight on my bike but I was able to crack them loose with a regular allen wrench.  Be careful to remove and save the crush washers as they will definitely be needed on the reinstall.
« Reply #8 on: Today at 04:00:40 AM »
You need to have the top caps on in place to put enough pressure on the springs to hold the damper tight to unscrew the Allen bolt, then used an impact gun or hand impact driver to break free the allen bolt. Then remove the top cap from the fork. Clean the inside out very well before reassembly.
