Author Topic: wheel bearings  (Read 824 times)
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: wheel bearings
« Reply #25 on: January 27, 2026, 12:34:27 PM »
be careful using naval jelly on chrome.
Navel jelly will not harm chrome. Just neutralizes rust!
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline crashmaster
  • 1972 CB 750 K2
Re: wheel bearings
« Reply #26 on: January 27, 2026, 01:26:09 PM »
That's weird because my jar of  Loctite navel jelly says not to use it on chrome also, so I haven't been. Would be nice to know if I could. Any chemists out there?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: wheel bearings
« Reply #27 on: January 27, 2026, 03:58:23 PM »
Well the manufacturer is mire credible than i.
I have used it with no ill effects.
I prefer SOS pads.
Offline ofreen
Re: wheel bearings
« Reply #28 on: January 27, 2026, 06:26:23 PM »
...and try to clean up the rusty rims (not gonna be fun).
Rust on the inside or the outside of the wheel?  I've used simichrome paste on chrome that wasn't pitted too deeply and have been surprised by the results.  On the inside, a wire wheel, some block sanding to get a reasonably smooth surface, rust converter if there is enough rust left to convert, then silver rustoleum.  It will stay good for a long time if you do that.
Greg
'75 CB750F
Offline crashmaster
  • 1972 CB 750 K2
Re: wheel bearings
« Reply #29 on: January 27, 2026, 06:40:14 PM »
Good tips - thanks!
I think I will re use the bearings. They seem fine. Bit I did have a question upon taking the wheel apart for possible future reference. What are the dimples that I have an arrow pointed to in the attached pic? Thanks
Online denward17
Re: wheel bearings
« Reply #30 on: January 27, 2026, 06:54:00 PM »
Good tips - thanks!
The dimples are there from the factory to keep the retainer from turning out over time.
FYI, they need drilling out to remove the retainer ring.
Edit to add picture of 550K hub just to show threads and dimples.
« Last Edit: January 27, 2026, 07:01:57 PM by denward17 »
Offline low-side
Re: wheel bearings
« Reply #31 on: January 27, 2026, 07:00:56 PM »
Yeah, 1/8" drill 1/8" deep is all it should take and the retainer will turn out, either with a special socket or careful use of a punch.  After servicing, you'll want to re-stake (dimple) it
Offline crashmaster
  • 1972 CB 750 K2
Re: wheel bearings
« Reply #32 on: January 27, 2026, 07:16:07 PM »
Thanks . I saw a video of someone making a tool to remove the bearing retainer, and he did drill them out. Now I know why!
Offline kyle750
Re: wheel bearings
« Reply #33 on: January 27, 2026, 08:31:52 PM »
On both my CB750 and CB550  I replaced the old wheels and spokes (very rusted).   I reused the old wheel bearings because I did not know how to take the old ones out ???  I cleaned and regreased the old bearings.   I did replace the old brake pads and shoes.  After truing, all 4 wheels run very straight with no wobble so I am quessing the old wheel bearings are OK?
« Last Edit: January 27, 2026, 08:52:11 PM by kyle750 »
Offline Deltarider
Re: wheel bearings
« Reply #34 on: January 28, 2026, 12:22:18 AM »
These bearings are generic: you can buy the best-of-all versions from SKF, but you'll pay for them - and they WILL be superior bearings. That's all I use.
Yep, SKF is best; Swedish steel, best there is.
CB500K2-ED Excel black
"No one is illegal on stolen ground."
Offline newday777
Re: wheel bearings
« Reply #35 on: January 28, 2026, 12:50:43 AM »
" I cleaned and regreased the old bearings"
" so I am quessing the old wheel bearings are OK?"
Did you stick your finger in each bearing and turn your finger to feel for roughness and notchiness after?? That is the only way answer your question. We can not apart from that.
Stu
My current rides
Prior bikes....
Offline kyle750
Re: wheel bearings
« Reply #36 on: January 28, 2026, 02:22:05 AM »
I actually did stick my finger in and turn the wheel bearings around.  Very smooth inside with no nicks or rough areas and the bearings turned very smoothly but solid and very firm. I could not see or feel any wear anywhere and the overall condition of the 4 wheel bearings looked like new. All 4 axles were in very good shape - black with grime but no rust or corrosion.  There was some corrosion to the axle around the outer wheel spacer on the CB550 so the axle was hard to get off but once removed the rough area sanded off easily and was smooth and OK on final assembly.
Offline jlh3rd
Re: wheel bearings
« Reply #37 on: January 28, 2026, 04:27:59 AM »
yep, I wasn't giving my opinion, I looked it up.
I do know that certain and stronger acids will start to darken chrome after a certain amount of time, ask me how I know.
Once it's changed the chrome, you can't fix it.
Offline kyle750
Re: wheel bearings
« Reply #38 on: January 28, 2026, 04:37:58 AM »
I just found photos Kannika sent to me while she was sanding the inner wall of the CB750 rear hub.  Wheel bearing was reused.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: wheel bearings
« Reply #39 on: January 28, 2026, 07:05:03 AM »
Nice clean hub!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Johnie
Re: wheel bearings
« Reply #40 on: January 28, 2026, 08:05:37 AM »
I went the other way as to the wheel bearings. I replaced all of them on all the bikes I have done in the last 25 years. Peace of mind I guess. But years ago seemed replacement was recommended. Easy to do and I just thought traveling at highway speeds I didn't need one to fail. Plus bearings were affordable.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
