I have heard that modern rectifier/regulators gives full power constantly. Regulate by burning via a resistor.
The old CB's have a throttle design.
A friend of mine talked about issues when using low wattage bulbs as LEDs on his bike. More overcharging had to be burned up.
I have tested Shottky diod rectifier. It gave a little more at around 2000-2500 rpm. But started to give 0.4V less around 4000rpm after 1 hour ride or so. The cooling alu plate it is mounted on was warm, not hot. Same with the Schottky.
Stock rectifier gives 14V at around 3600 rpm with headlight on.
I can swap between schottky and stock by reconnect wires
The alu plate with schottky is fastened in stock rectifier.
When regulator is properly adjusted and all connectors to-from regulator- alternator windings and rectifier side to battery are tight and free of oxide, stock charging system works fine.
It needs much to get it to stop work.
Most important is to avoid cheap batteries. I got a sudden totally dead battery last summer on my K2.
Charging voltage was over 14V all rhe time. Stopped for gasoline refill.
Ignition on , starter. Totally dead, pilot lamps died too.
Called a friend that live 75km away from that gas station. He brought a working battery.
Swapped batteries and I could ride home.
Battery was 2 years old. Recharged every month, 2 months as minimum.
I had another cheap battery of same kind I could follow with my battery tester. It was bad after 1 year of use. I threw it away after a few months since it became worse despite charging.
Save $100 US in battery can end up in a higher cost when stranded far away from home.
Bikes have now medium priced AGM batteries for around $150 US.
They behave well, not quick discharge. Need a refill after 2 months of bike being parked.
The cheap batteries have less lead. The acid level is higher so battery voltage is around 13.5V.
Expect max life of 2 years. And sudden death.
I had another really cheap since they had reduced price from $50 to 40.
It died after a little bit more than a year.
Quick discharge by just sitting disconnected. Health Cond Cranking Amps not possible to charge over a healthy level
Cheap batteries many years ago just became weaker on the starter. Use the kick, start it and ride.
Below schottky rectifier, clamped with an alu plate, thermal paste where it should.
