Author Topic: super bike bars on a 75 CB750F SuperSport  (Read 2425 times)
qcextreme
« on: June 20, 2005, 05:21:24 PM »
I just replaced my stock bars with some super bike bars and now I got a speed wobble when I let go of the bars @ 30-40mph, I have took it up to 60mph with both hands on the bars and she seems ok, Why would the new bars do this?? Is it because there not weighted on the ends like the old bars?? any help would be great
Offline mutters
Re: super bike bars on a 75 CB750F SuperSport
« Reply #1 on: June 20, 2005, 06:20:16 PM »
I cant imagine the change of bars causing this much drama.
perhaps something else came loose during the operation?
I would go looking for other sources of the problem,and experience has shown that wobbles at the front could very well be caused by problems at the rear, like wheel bearings and things.
There that should confuse things.
                                               y'all have fun now,Jeff
I know its only rock and roll,
but I like it...
« Reply #2 on: June 20, 2005, 06:47:43 PM »
Sometimes it is just the way it is.
qcextreme
« Reply #3 on: June 21, 2005, 06:36:27 AM »
is there anything I can do to fix it? other then putting the old bars back on
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: June 21, 2005, 06:53:54 AM »
The "logical fault-finding engineer" in me says put the old bars back on and see if the fault goes away.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
qcextreme
« Reply #5 on: June 21, 2005, 07:00:57 AM »
I have all ready did that and yes it did go away, but when I put the new bars back on it was back, is there anyone else running the superbike bars? did this happen to you??
douglascoolgrey
« Reply #6 on: June 21, 2005, 09:23:23 AM »
what kind of bars were you running before? Perhaps you're carrying your weight differently on the front end of the bike.
qcextreme
« Reply #7 on: June 21, 2005, 10:28:40 AM »
the old bars are the stock ones, I just took her out for a ride, ran her up to a 100mph and she rode fine, went by the honda shop and order some steel bar ends to add a little weight on the bars, hopefully this will work, I think I'll have the front tire balanced again aswell..
Offline MikeDeB
« Reply #8 on: June 21, 2005, 11:30:06 AM »
You might also look at servicing the steering stem bearings.  If they are worn, now's the time for a set of tapered roller bearings.  I'm running clubmans on one K and GP Tour's on the other with no problems but both bikes have good steering stem bearings.  Also, no bar end weights on either set.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Mikeshonda750F
« Reply #9 on: June 21, 2005, 05:22:53 PM »
Well, you certainly narrowed it down by replacing your new bars with the factory ones... so you know its not anything else.
Is it possible that the new bars stick out further or sit higher/lower and allow wind to catch the mirrors/clutch/brake/electrical differently?
It could also be that the new bars are light enough that they allow slight movment to reverberate... but im guessing its something else (like a windshield foiling air onto a mirror or something)
Offline Uncle Ernie
« Reply #10 on: June 21, 2005, 05:39:25 PM »
I'm thinking that the change in weight distrbution is showing up a problem somewhere. Either the extra weight on the frone wheel is showing up a bad (or in need of tightening) steering head bearings, or the slight  weight shift has shown up bad rear wheel bearings/ bad swing arm bushings, low air pressure, etc.
