Author Topic: cable routing CB750  (Read 23793 times)
Offline Donzon
  • CB750K4
cable routing CB750
« on: April 18, 2007, 09:35:13 AM »
Does anyone have or can point me to photos of the routing for the clutch and throttle cables?  I switched to drag bars and clutch is stiff, throttle doesn't snap back anymore etc.  The cables worked OK before and I've tried several different configurations but I just can't seem to get it right.  I don't have any really tight bends, but still no luck.  The clutch is not a big deal but the throttle cable thing is a problem.
Thanks
Don
Offline Gordon
  • 750K1, 550K2
Re: cable routing CB750
« Reply #1 on: April 18, 2007, 09:37:06 AM »
Your best bet is to get shorter cables to compensate for the shorter bars.
Offline Donzon
  • CB750K4
« Reply #2 on: April 18, 2007, 09:40:55 AM »
I can shorten the cables no problem, but I think it's the routing under the gas tank that I'm doing wrong.
Don
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #3 on: April 18, 2007, 09:48:57 AM »
When I swapped in my drag bar I had hella problems too.  In fact I bent the clutch cable so bad I could barely move it.  So, I ordered all new cables.  I used Suzuki GS500 cables for the throttle and they are the perfect length.  I bought an aftermarket clutch cable from bikebandit and just routed it until it didn't bind when I turned the handle bars.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
« Reply #4 on: April 18, 2007, 10:21:09 AM »
I am also interested in this questions as Ive run into a similar problem with my K4 rebuild. Questions is should the wiring harness go through the triangle space (under the top down tube) and OVER the coils or ALONG side of the coils. If ALONG side of the coils then the BOTH throttle cables have enough room to go OVER the coils, through the triangle space and attach to the carbs. Anyone got pics of a working situation? My difficulty may be I have CB900 coils which are a little bigger I think than stock.....
cheers
Andy
Offline merc2dogs
« Reply #5 on: April 18, 2007, 11:05:46 AM »
 I've always routed the pull cable over to the left side of the neck, then ran it along the backbone above the coils and then to the carb, don't pass it through the triangle, if you do that it makes two sort of sharp bends and is too stiff.
 the othewr cable (close) I run on the other side of the neck, and then through the triangls, it doesn't seem to bind that way.
 Mine had automatic cruise control when I bought it, pull your hand off and it stayed there.
 On the clutch, I run behind the headlight bucket,ziptied to the frame between 3 and 4, then down to the clutch
 when I first got it, it was through the speedo loop, and felt real stiff, not going through the loop loosened it up enough to be comfortable.
 tried shorter cables, and for some reason couldn't get them to work right.
Ken.
Offline Kevin D
  • SE Michigan
« Reply #6 on: April 18, 2007, 03:37:58 PM »
Took this photo before disassembly, Throttle cables under coils, harness over coils. I'm battling with the harness now, to get the harness under the gas tank bushing so the tank will go on smoothly.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #7 on: April 18, 2007, 05:04:04 PM »
One throttle cable over coils through the triangle goes to the lower throttle return connection making gradual curves. The other cable under coils goes straight back to the throttle pull connection.
« Last Edit: April 18, 2007, 05:12:56 PM by RxmanGriff »
Offline Donzon
  • CB750K4
« Reply #8 on: April 18, 2007, 08:25:52 PM »
Thanks for the help guys, it gives me something to go on.  Mine is a K4 as well.
I thought about shorter cables but I figured it must be something else, as the cables actually bend less sharply now than they did before.  Most annoying part is the bike looked like absolute hell and had sat for years before I started the rebuild but all this stuff worked fine and now after a zillion hours of cleanup and repairs this silly crap is keeping me tied up.
Thanks
Don
