Author Topic: Am I getting this right?  (Read 990 times)
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« on: April 18, 2007, 09:30:16 AM »
'75 550K1:
I'm looking at new sprockets & chain.  I know the stock sprockets are 17T front & 37T rear (2.18 GR), with a 100-link 530 non-O-ring chain.  I think that chain must be bought in even number links (alternating link pattern).  I think if you change one tooth size, just reposition the axle.  If you change a number of teeth size gain/lose 1/2 link per tooth.  So 3 tooth change is 1-1/2 link change. Sooooooooooo:
If I go with 18T front & 37T rear (2.06 GR), I can still use the 100-link chain?  (=lower RPM: better cruising/gpm & worse pickup)
If I go with 17T front & 34T rear (2.00 GR), then I have to lose 2 links, so I get a 98-link chain? (=same thing, slightly more pronounced)
And while the o-ring is a no-no on 550's, the options are standard (20.45 mm pin length) or heavy duty (22 mm pin length).  My trusty calipers tell me that the chain I'm currently running has a 22 mm pin, so I'm inclined to go with the HD chain.
Any recommendations as to which way is preferrable: 18/37 or 17/34?  I'm thinking the 18/37 because the chain remains the same at 100 links. Thoughts?
Thanks
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline OldSchool_IsCool
  • Really feeling like an
Re: Am I getting this right?
« Reply #1 on: April 18, 2007, 10:12:49 AM »
A larger front sprocket (i.e the 18) will roll your chain over a larger diameter thus lessening it's stress and wear.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
