I could use some input from those of you running the CR's, please. Mine are newly installed on my 836 bike. I've done a lot of carburretor tuning over the years, but this set-up has me puzzled. They are fresh out of the box and have the K&N's installed that are sold with them. I started it up and rode it Saturday for the first time since the rods, studs, and chain upgrades. I only rode it 10 miles as rain was going to happen - just wasnt sure when. Yesterday I rode some more to check for leaks and bring it up to temps, then to check for idle adjustments at the air screw and idle speed. - rode a little better.
Here is the deal -
These only have about a 1/3 throttle turn from fully closed to fully opened, so metering the throttle is quite a bit more delicate than stock. The carbs will not allow any "quick" throttle opening. If you twist the throttle open at low, middle, or anywhere before 7,000 - the huge air signal is dry and therefor causes the motor to die momentarily. If you twist it open at 7,000, you get a few blubbers (rich), but it quickly goes into it's hardest and most exciting pull of it's range. If these transitions in throttle are made moderately - then it never has a dead spot, lean spit, or rich blubbering. This makes me thing the jetting is ok. I also measured cylinder head temps throughout the ride to confirm I wasn't melting something. Normally a problem like this - I'd raise the needle clip to cure what would be a dead spot in the middle and a lean spit, then drop the mains by 1 size to cure a rich condition that persisted regardless of application. Here I can get low, middle, high perfomnace from each circuit as -is, but you can't open the throttle before the engine can use it. On a regular carb - I'd never be able to transition through it.
I would say an acellerator pump is designed to cure such problems on autos. They squirt about 5cc of raw gas into the intake manifold when the pedal is floored to help cure the exact symptom. Am I missing something about tuniing the CR's or am I finding something that is to be lived with and expected? or is there a cure?
Thanks,
Gordon
![](http://star.walagata.com/w/ilbikes/147484162066.jpg)
