Author Topic: bottom Air  (Read 10092 times)
Offline ieism
bottom Air
« on: April 20, 2007, 10:17:02 AM »
Hi,
I just took my 550 out of the garage, and notice that the most of the bottom air from the reartire is missing. It looks like the top air is still there, so it seems like a waste to replace all the air. Is there still OEM bottom air available from Honda, and where can I find some. And is there a difference between frontire air and reartire air?
---cb550---
Offline dusterdude
Re: bottom Air
« Reply #1 on: April 20, 2007, 10:26:00 AM »
honda sold their bottom air to harley-davidson a few years ago,you have to go to a harley dealer to get it.i hear its kind of expensive too.good luck.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Rsnip988
Re: bottom Air
« Reply #2 on: April 20, 2007, 10:36:33 AM »
you can buy OEM honda Bottom air on Ebay for around $239
but if its the sandcast bottom air it'll be $894
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline ieism
Re: bottom Air
« Reply #3 on: April 20, 2007, 10:53:22 AM »
Yeah, but I don't really trust E-bay. how do I know they're not just selling me top air for the price of bottom air? Obviously the OEM bottom air is more rare than the top, but $239 seems like a ridiculous price to me.
The Harley dealer told me he could sell me the air for $78, but i need an adapter to install it. Just the adapter is $173.
---cb550---
Offline dusterdude
Re: bottom Air
« Reply #4 on: April 20, 2007, 11:15:10 AM »
sounds like you are in a bit of a pickle. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline DammitDan
  • Prodigal Son
  • It lives!
Re: bottom Air
« Reply #5 on: April 20, 2007, 02:37:13 PM »
What model/year is the pickle?
CB750K4
Offline Steve F
Re: bottom Air
« Reply #6 on: April 20, 2007, 07:03:56 PM »
I wouldn't bother with the old top or bottom air since you need to replace it with summer air now anyway.
Offline mrbreeze
  • Not your average
Re: bottom Air
« Reply #7 on: April 20, 2007, 09:47:58 PM »
Hi,
Last time I checked....the Honda stealership had quite a bit of bottom air on a shelf right next to the 5 gallon buckets of Ohms.I asked if I could just buy a quart but they said no.So.....I spent most of my cash on enough Ohms to last quite awhile. That left me a little short to get enough blinker sauce!! Maybe next payday.......God I hope....those suckers sure are blinkin slow!!!!
MEMBER # 257
Offline Rsnip988
Re: bottom Air
« Reply #8 on: April 20, 2007, 10:20:55 PM »
maybe Tery in Oz can fabricate you an adapter for $20
he seems pretty good at making other things
R.K.S.
1976 CB750 K6 Full
Offline ieism
Re: bottom Air
« Reply #9 on: April 21, 2007, 08:59:08 AM »
Well I think I've solved it!!! I must be a genius for coming up with such a cheap and elegant solution. I took two tirepumps apart and connected the two hoses together. I used a bit of pipe, and some hoseclamps.
I then made sure the valve stems of my frontwheel and backwheel where exactly at it's lowest point. I then connected the hose to the frontwheel's valve, and let some air from it into the rear. I've now effectively doubled the amount of bottom air in my reartire, and it only cost me $2!!
I'll testride it later this weekend and see how it works out.
---cb550---
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: bottom Air
« Reply #10 on: April 22, 2007, 08:30:49 AM »
The real problem is that you never know if you are getting OEM bottom air for the prices they charge. It's not uncommon for a dealer to use cheap imported product from you-know-where and then put official looking labels on it.
The stuff from HD is expensive because it is processed at a higher temperature. They are renowned for the hot air they produce.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline nickjtc
Re: bottom Air
« Reply #11 on: April 22, 2007, 08:31:33 AM »
2005 Vlasik, with garlic.
1977 Suzuki GS750
upperlake04
Re: bottom Air
« Reply #12 on: April 22, 2007, 09:06:20 AM »
 If the hose idea doesn't work you could do a swap with someone from New Zealand or Oz. Be sure to get their top air though.
Offline ieism
Re: bottom Air
« Reply #13 on: April 22, 2007, 09:21:16 AM »
Well, I testdrove it around the block. I have to be honest, it's not great. It seems to bottom out over mediumsized bumps. I'm hesitant to take it on the freeway in this condition. >:( I think it needs more bottom air still...
That's not a bad idea really. Yo Terry (or anyone else in OZ)  lets set this up propely so everybody on the forum can have enough air!
---cb550---
Offline Rsnip988
Re: bottom Air
« Reply #14 on: April 22, 2007, 06:18:06 PM »
dont forget that sometimes you can find origional bottom air in bike salvage yards
R.K.S.
1976 CB750 K6 Full
Offline Rushoid
  • Shameless
Re: bottom Air
« Reply #15 on: April 23, 2007, 07:08:39 AM »
Senor Breeze,
I have a little extra blinker sauce/brake light fluid and a spare mud clutch. I can always use some Ohms because I have a leak that I just can't locate. Care to make a trade?
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
Offline mrbreeze
  • Not your average
Re: bottom Air
« Reply #16 on: April 23, 2007, 07:56:22 PM »
Senor Breeze,
Oh yeah.....I'm in!!!!! I'll take all the blinker sauce ya got for 2 qts. of Ohms.I'm also in the market for a left side cover adjuster but it has to be metric!!! Let me know!!!!
MEMBER # 257
Offline Flood
Re: bottom Air
« Reply #17 on: April 24, 2007, 02:45:03 AM »
OK, there's an Old Timer trick to all this: what you need is not really AIR, but COMPRESSION. Not many people know that Honda uses the same compression in its engines as well as in the wheels.
Only the part numbers are different! So go to your local dealer and get a can of compression, they are right by the ohms and the sparks.
Offline nickjtc
Re: bottom Air
« Reply #18 on: April 24, 2007, 06:32:20 AM »
Senor Breeze,
Count me in too! I've been buying up '60s muffler bearings like crazy from eBay before the market explodes, so I'd consider a trade too.
Is that mineral based Ohms or synthethic, incidentally?
1977 Suzuki GS750
Offline Rushoid
  • Shameless
Re: bottom Air
« Reply #19 on: April 24, 2007, 08:34:48 AM »
Senor Breeze,
Oooh! Are they chrome-plated muffler bearings? I need a full set for my bike and I'd be interested if you're offering.
Breeze, I only have the right-side adjuster. I broke mine when I dropped my water transformer on my board stretcher. Geez, what a mess. I'm sure you can imagine. Bumper grease everywhere.  ::)
SOHC/4 Member #3452
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: bottom Air
« Reply #20 on: April 24, 2007, 08:47:47 AM »
I've always had good luck using "Political ideas" instead of bottom air, other then it likes to migrate to top air, and sometimes left and right air.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Re: bottom Air
« Reply #21 on: April 24, 2007, 03:41:53 PM »
You Americans are a right sad lot,...ya don't know jack sh1t.
The cheapest air, be it top or bottom is available right on your doorstep.
Contact Big Jay at APE in Willow Springs,...he imports air from China and modifies it for drag racing.
You can buy it loose or in paper bags a lot cheaper than in pressureised canisters.
You can contact Jay at www.aperaceparts.com or PM him on this forum for a price,...you'll not be dissapointed.
It's sad when you have to turn to an English man to sort your silly little problems out.
Sam. ::)
Offline mrbreeze
  • Not your average
Re: bottom Air
« Reply #22 on: April 24, 2007, 08:06:26 PM »
Thanks for the tip Sam!!! I never see what I need in the catalog......Oh and Rushoid......I'd be interested in that right side adjuster cause I can invert it and it will be fine. Better than tryin to reprogram a Suzuki unit that will never be at the right frequency!!! Also needed.....anyone??...... A pair of left handed sky hooks so I can rotate my spoke converters. I would be soooooooo grateful!!!!
MEMBER # 257
Offline sparty
  • I just play one on TV
    • Gallery
Re: bottom Air
« Reply #23 on: April 25, 2007, 06:18:59 AM »
When my bottom air went bad I replace it with nitrogen.  It is a great upgrade.  I had to make a few minor adjustments to the frame and handlebars, because the nitrogen is not OEM. :D
Sparty
1972 CB750 K2 Cafe' Style
Offline medic09
Re: bottom Air
« Reply #24 on: April 25, 2007, 01:29:20 PM »
Sparty
I'd be careful with that.  Nitrogen is a lighter gas than complete air, and moves faster.  You may need higher pressures to fill and keep it from shifting in the spaces.  Either that, or install baffles.  Otherwise, on bumps it may shift round and become top air, or it may slosh in tight turns, especially esses.
Where's TT or one of those guys when we need them?
 ;D
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
