That would be it. Great little battery. It has a lower amp hour rating but delivers more amps but that is always a trade off. Kinda like when you add more batteries together. The more you add, the higher the voltage which is able to then overcome the internal resistance and deliver more amperage but the batteries will run down quicker. But in this case, the glass mat holds the solution onto the plates for better coverage which produces more amperage but about the same voltage.
