Author Topic: CB360 Vs. CB350...  (Read 16192 times)
Offline SClay115
CB360 Vs. CB350...
« on: April 20, 2007, 06:42:57 PM »
What are the more important differences between the two? I see a lot of the obvious ones, but I think there are many that I'm missing. But one particular question, are the carbs the same that come on both? They look almost identical...
Steve
EDIT: While looking through some CB360 parts, the bottom ends look almost identical...what gives? Did Honda just slap some oversized jugs on the thing and call it a 360?
« Last Edit: April 20, 2007, 06:44:53 PM by SClay115 »
Offline gerhed
Re: CB360 Vs. CB350...
« Reply #1 on: April 21, 2007, 04:36:15 AM »
I had a 360 in a 3-wheeler I built a while back.--good strong motor.
I think the major difference is the 6 speed in the 360.
          83 XL600R in CB360 Frame
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« Reply #2 on: April 21, 2007, 04:55:08 AM »
The 360 motor is basically an enlarged 350 motor. The head is different and the tranny is 6 speed. You are getting about 30cc more engine than the 350. Isn't that strange? The carbs are slightly larger but basically the same design. There may be more vibration to the engine. It's an evolutionary design. The 350 is said to be an evolution of the 305, but they seem quite a bit different to me. :)
« Last Edit: April 21, 2007, 07:34:51 AM by CBGBs »
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline SClay115
« Reply #3 on: April 21, 2007, 05:36:45 AM »
Can you put a 350 engine into a 360 frame? Seeing as how the cases look very similar? Seems like there are FAR more parts for the 350 engine, as far as performance goes, than the 360...and I have a spare 350 engine that would LOVE to get some high compression pistons and a nasty cam...
Steve
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #4 on: April 21, 2007, 06:11:28 AM »
THe 350 motor is basically an enlarged 350 motor. The head is different and the tranny is 6 speed. You are getting about 30cc more engine than the 350. Isn't that strange? The carbs are slightly larger but basically the same design. There may be more vibration to the engine. It's an evolutionary design. The 350 is said to be an evolution of the 305, but they seem quite a bit different to me. :)
           Hey Kyle,
                   I was always puzzled about the 350 basically replacing the 305 myself. Nothing against the 350, but (as you know) it's a totally different motor than the 305. Always had a soft spot for the 250/305 motors. ;) I'd sure like to be able to feel the performance of a 305 boosted up to a 350 w/ one of those Powroll kits (or something similar) myself. Not intending to hijack the 360 Vs 350 thing so I'll go. ::)
                                                         Later on, Bill :) ;)
Member # 1969
Offline CBGBs
« Reply #5 on: April 21, 2007, 07:40:08 AM »
It seems to me that the motor mounts are simillar, although I can't get a good pic of the top mount.Since I've seen a CB350f motor in a CB77, I'd say that putting a 350t in a 360 would be easier than that. Go for it!
Offline SClay115
« Reply #6 on: April 21, 2007, 08:10:07 AM »
Yeah the 360 top end has a head similar to a SOHC4, as apposed to the CB350 twin. So I would assume the mount is different. But being as the mounts are simply plate steel, I'm sure I could make something work....evil thoughts....
Steve
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #7 on: April 22, 2007, 04:29:40 PM »
the 360 lower frame rails are equal height, Where the 350 has the right rail lower!  Don't know for sure about the top side frame differences.  also the 350 has an access plate for the oil filter and the 36- needs to have the clutch cover removed to get to it.
These are some of the diferences. As I've heard the 360 came about for emissions issues.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline Pinhead
  • 1979 CB652-ST
« Reply #8 on: April 22, 2007, 05:21:39 PM »
I've also heard that the 360 had problems with the cam chain tensioners and it's virtually impossible to find an aftermarket replacement. The sleeves are bigger, allowing for a larger oversize bore than the 350 had. Generally the 350 had more power and was better geared than the 360 (even with the 360's extra gear). Overall the 350 was a "better" bike than the 350 unless you have unlimited funds to build a hotrod twin.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline crazypj
  • I'm brill, me
« Reply #9 on: April 24, 2007, 10:46:00 PM »
I thought we had already done this?  ???
You can fit a 350 into a 360 frame but not the other way round. 360 motor is taller and slightly wider, wont go into a 350 frame ( I already tried)
360 has totally different cylinder head and oil pump set up to 350, hell its a  different motor. Not sure about transmission ( if it will swap into 350) as Honda frequently went through the parts bin to make somewthing 'new'
In my opinion its a waste of time as the spread between gears isn't very good.
360 has cam oiling issues which can be overcome by some minor machine work (after a full engine strip ::))
Even with all its faults, I like them and have 4, unfortunately without titles ( didn't know what was involved getting bikes titled in USA :( :()
PJ
