Author Topic: How to Remove the Emulsion tubes from Carbs  (Read 2790 times)
Offline doug_id
    • My Cafe 550 Project Gallery
« on: April 27, 2007, 06:23:45 AM »
Ok....I tried search and see a lot of talk about how they need to be cleaned but one question.......how best to remove them?
Thx!
Doug
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline .RJ
  • homebase in your airspace
Re: How to Remove the Emulsion tubes from Carbs
« Reply #1 on: April 27, 2007, 06:55:42 AM »
The way I knocked the tubes out was to spray down the tube from the top and bottom with carb cleaner to try to dislodge any crud, take the slides/needles out of the topside of the carb and you can tap it out with a small punch and a small dead-blow hammer.  They should drop right out.
« Reply #2 on: April 27, 2007, 08:42:01 AM »
Usually, if they need cleaning, they will not simply drop out.  Find a soft dowel, hardwood, nylon, brass, etc. and tap them out from where the slide needle inserts.  They come out the same hole the main jet rests in.  Remember, you are tapping on the needle orifice and any distortions in that will effect fuel metering.
Offline doug_id
« Reply #3 on: April 27, 2007, 08:50:46 AM »
Thx Guys,
I am still running rich on 3 cylinders so I will look at these tubes as the possible culprit.
+ I just luv pulling the carbs....hehe...... ;)
02 Concours
78 CB550
