Author Topic: More What Are These???????  (Read 1523 times)
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
« on: May 07, 2007, 06:59:35 PM »
I just got a complete gasket set and have no idea what these three items are. Pic 1 is some sort of rubber disc with a heavier bead around the edge. Pic 2 is a rubber cylinder with beveled openings. Pic 3 is a metal ring with corrugations on the inner and outer surfaces. Your wisdom is appreciated.
Jeff
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
Offline mkramer1121
Re: More What Are These???????
« Reply #1 on: May 07, 2007, 07:03:03 PM »
Pic 1 are the gaskets that go under the cam towers.  Pic 2 looks like a valve stem oring.  Pic 3 could be exhaust gaskets (though they're really weird if they are).
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 07, 2007, 07:12:25 PM »
Without a size reference I can't say with 100% certainty, but #3 looks exactly like an exhaust header gasket to me.
Offline Jonesy
  • Shop Rat
« Reply #3 on: May 07, 2007, 07:19:43 PM »
#1- As other said, those are the rubber sealing "pucks" that cover the large bolt access holes under the cam towers.
#2- Looks like the oil feed passage seals that go between the case/cylinder and cylinder/head (they are cylindrical in shape and supercede the O-rings that used to go in there). Those look like the ones I got from Honda when I rebuilt the top end on my uncle's 750 last summer.
#3- I concur it looks like the exhaust gasket.
Offline Dusthawk
    • My MySpace Place
« Reply #4 on: May 07, 2007, 10:17:50 PM »
O.K., here is where I am at this point. The rubber cyninders in the second hoto above do not fit any gelleys anywhere on the head I have. I'll figure it out later I guess. After removing eight, yes eight, copper exhaust gaskets from the the metal rings fit perfectly in the recesses, so I guess that is what they are though I have never seen one like these, just copper or asbestos. Anyway, on to the new photo. I have already figured out what #2 is for, no problem there. Numbers 1, 3, and 4 though have me at a loss. The sizes are:
#1: 1/8" i.d., 1/4" o.d.
#3: 7/16" i.d., 9/16" o.d.
#4: 2.5" i.d. (big)
I don't have the rest of the engine with me but I would guess that these either fit in the case or on the cam towers.
More wisdom for me?
Offline scondon
  • Mmmm......tasty bugs
« Reply #5 on: May 07, 2007, 11:06:37 PM »
First pics:
#2: Jonesy got it right, and your cylinders don't use these so set them aside.
Last pic:
#1: oil feed passages under the cam towers. You should have four of these.
#2: oil feed passages between cylinder/head and cylinder/base. Again, there should be four
#3: These look like the oil line(from oil tank to engine) orings. There should be two of these. If there are three of them then they are the o-rings for your oil pump. hard to judge actual size from your pic.
#4: These fit at the base of the cylinder sleeves. You should have four of these.
  Sorry for not gettin' back to you sooner, Jeff. Congrats on the new place :)
Offline Raul CB750K1
« Reply #6 on: May 07, 2007, 11:31:05 PM »
I recently bought an original Honda carb o-ring set. There was a metal washer I couldn't imagine where did it go. With the set there was a paper that, obviously, I didn't take the time to read thinking it was just a parts list.
The o-ring set part number was different than the one I order, but I just thought it had been superseded sometime in the past. By reading the enclosed paper I understood what was going on: the set I bought was superseding two different o-ring set for two different models, and depending wich one you were using, some parts were going nowhere. That is, the set had a number of common o-rings, and then specific o-rings for two different carb models, and you had to use only the ones you need depending on the model you had. I guess Honda reckoned it was cheaper to reduce the number of o-ring sets than to throw away some washers or o-rings that would be never used -though the customer would pay for them at the end-
Could it be that it is the same case than yours?
Raul
Offline Dusthawk
    • My MySpace Place
« Reply #7 on: May 08, 2007, 12:19:05 AM »
I don't know for sure Raul, this is an Athena kit but there are no arts list or descriptions included. I'll just have to muddle through ;D ;D ;D
Jeff
Offline Dusthawk
    • My MySpace Place
« Reply #8 on: May 08, 2007, 04:27:54 AM »
Just thought of another question. I have a head from a 77 or 78, can the exhaust mounting studs be removed to allow the spigot to be mounted in its place?
Jeff
Offline mkramer1121
« Reply #9 on: May 08, 2007, 04:45:06 AM »
Response to your last question:  YES.  I'm going the reverse on my 750.  From spigots to studs.
