Author Topic: Are 79 DOHC 750f brakes compatible with a 77 750F?  (Read 1365 times)
Offline billdramp
  • DOOMTOWN RIDERS / PORTLAND, OR.
« on: April 28, 2007, 03:42:15 PM »
They look the same on the bikes... But you know how that goes!!
I used the search function but came up empty.
Anyone tried this successfully. I'd like to know before plopping down the cash for the DOHC brakes.
Billy
1975 CB750K (daily rider), 1974 CB550K (sold), 1974 CL350 (sold), 1973 CL350 (when I get around to it...), 1971 CB750 (in boxes), 1978 CB750F in boxes, 1976 CB750F SUPERSPORT (sold), 1975 CB400 FOUR (crashed), 1976 400 FOUR (work in progress), 1977 cb400f
SOHC4  MEMBER #1527
Offline billdramp
Re: Are 79 DOHC 750f brakes compatible with a 77 750F?
« Reply #1 on: April 29, 2007, 11:18:44 PM »
Bump...
Anyone?
SOHC4  MEMBER #1527
Offline Soos
« Reply #2 on: April 30, 2007, 12:28:12 AM »
Ok, I was waiting for someone else to chime in.
I don't have the exact answer your looking for, but I do know that the '79cb750 front brakes mount right up to a '79cb650 fork.
My bike origionally had only one brake mount, and since I had 2 pairs of forks(both off '79cb650's), I was going to run with one brake set mounted correctly(behind the fork leg), and the other mounted in front instead in the back of the fork.
Looked FUNKY though.
That is until I measured a bit more, and found the fork sliders are the same diameter between the two bikes.
I used the CB650 sliders, and the '79cb750 forks and brakes.
I would have used the '79cb750DOHC sliders as well, except they measured an inch longer than my 650's.
So to keep the stock stance of the bike I opted for the orig. sliders.
Hope I have shed a glimmer of light for you.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline mick750F
« Reply #3 on: April 30, 2007, 05:36:40 AM »
  If you're talking about calipers then the answer is yes but you will need the mounting brackets as well. Several members here have done the swap to dohc calipers to get the advantage of double pistons.
Mike
Glosta, MA
