Author Topic: How do I service and re-face 550 speedo & tach  (Read 1059 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
« on: April 30, 2007, 06:49:06 AM »
I recently replaced my pooched tach with what looked like a nice unit from Ebay.
Shortly after installing it, noise started to emit from it. It sounds like gear whine or possably a dry bushing.
I've also noticed real nice gauge faces available for these units and thought I'd open it up to cure it of the ghastly whine and paste a new face on it.
Problem is that I cant see how these gauges are serviced.
Can you shed some light on this subject.
Thanks
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: How do I service and re-face 550 speedo & tach
« Reply #1 on: April 30, 2007, 07:08:46 AM »
Oops.
Just spent a little more time searching the archives. Lots on this topic.
Thanks for keeping the flame throwers down.
Cheers
Jimmy
dminner
« Reply #2 on: April 30, 2007, 09:04:49 AM »
The chrome band that holds the top and bottom together needs to be cut.  I just used a dremel and cut one line and it will fall right off, the top and bottom can then be seperated.
Here is a pic of mine, if you look towards to bottom you can see the cut I had to make:
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: April 30, 2007, 11:30:25 AM »
If you go to Cheapo's site at www.anubiscycle.com he has a complete set of instructions (as well as selling the dials)
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Swede
« Reply #4 on: April 30, 2007, 11:58:56 AM »
If you go with Anibus be sure that you contact the owner first.  He has auctions on ebay and I purchased a set for my 76 550K.  When I got my gauges tore down and went to install the new faces the holes didn't line up.  I guess there are some minor differences between the screw holes in the 550's and 500's.  The screw holes on my gauges are spaced wider center to center than the ones he is selling.  He is making it all good though and providing me with a set of faces that don't have the pre cut holes.  My experience with Anibus has been great and I wouldn't hesitate to use his products.
dminner
« Reply #5 on: April 30, 2007, 12:09:05 PM »
This is true.  I got the cb500 ones for my cb550 (pictured above).  I had to make new wider holes and covered the others up with the washers shown in the pic
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #6 on: April 30, 2007, 12:14:00 PM »
Great info.
Thanks
Jimmy
Offline RFogelsong
« Reply #7 on: February 20, 2012, 04:28:28 PM »
Any info on what the "whine" was? I'm getting that noise out of my speedometer and I'm wondering if I'm gonna need a new cable because my guess is the noise is coming from the cable spinning in the housing.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
