Author Topic: What's your start up process?  (Read 11064 times)
Re: What's your start up process?
« Reply #50 on: May 02, 2007, 02:44:21 PM »
Why is it called a petcock and not a gascock ?  ::)
Sam. :D
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #51 on: May 02, 2007, 02:56:41 PM »
Sam. :D
You reach down to pet it? ::)
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
« Reply #52 on: May 02, 2007, 03:01:58 PM »
That is not a sensible answer James, you realy must try harder ::)  ;D ;D ;D ;D ;D
Sam. ;)
Offline clarkjh
  • Expert? If only.
« Reply #53 on: May 02, 2007, 03:06:10 PM »
Sam
I always get in trouble when I start thinking, usually trip and fall down.  Although I can chew gum and drive at the same time. :D
James
SOHC/4 #3328
« Reply #54 on: May 02, 2007, 03:10:43 PM »
I thought it was only girls that can mulitask.  ;D ;D ;D ;D ;D
Sam. ;)
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #55 on: May 02, 2007, 03:13:30 PM »
Moduleum;  I turn off the fuel at the petcock because a gravity flow fuel system plus a stuck open float could easily equal egg-shaped cylinders the next time you start it ;)
I've seen the aftermath and it ain't pretty :o
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
« Reply #56 on: May 02, 2007, 03:48:33 PM »
OK guys, it's time for the biggy,...starting the CR836 ::) ::) ::)
When we had the big motor built, we decided to leave out the kick start to cut down on weight (I wonder how quick it would be if Chris went on a diet  ;D )
We arrive at the strip and unload the van.
We jack the rear end of the van up and slide a set of start rollers under one of the drive wheels. The van is then lowered onto them.
We put the CR onto the other end of the rollers and Chris gets his leg over.  ::)
I get into the van and start the motor. I engage reverse gear and when Chris is ready I spin the rollers slowly and he selects 1st gear.
With everything ready, Chris lifts his weight off the seat and I spin the rollers up at a fastish rate, he drops the clutch and crashes his 280lb but onto the seat :o
The big motor spins up and we keep it like that for about 10 to 15 seconds to get the oil around the motor.
Once this is done I stop the roller while Chris puts the choke, ignition and fuel on.
When he gives me the OK, I spin the rollers, he drops the clutch and dumps his 280lb but on the poor seat again :'( :'( :'(
As soon as it fires, I stop the rollers and he takes the bike out of gear, freeing his left hand up to take the choke off.
The bike is then warmed up for about 5 minutes and is ready to go. ;D
Quite easy really :D :D :D :D :D
Sam. ;)
« Reply #57 on: May 02, 2007, 05:33:29 PM »
Sam. ;)
Just because they fall asleep while you're doin 'em Sam, does NOT mean they are multitasking, despite what they've told you.
 ;D ;D
Offline Gordon
  • 750K1, 550K2
« Reply #58 on: May 02, 2007, 05:34:53 PM »
 ;D ;D
And the gloves are off!!!
all ten of them.. :o :o :D
« Reply #59 on: May 02, 2007, 06:15:25 PM »
Sam. ;)
 ;D ;D
I would'nt know Lloyd, I've never had one fall asleep during...........
but they sure have after ::) ::) ::) ::) ;D ;D ;D ;D ;D ;D ;D ;D ;D
Sam 8)
Offline clarkjh
  • Expert? If only.
« Reply #60 on: May 02, 2007, 06:50:35 PM »
I think I'll quietly retire from this part of the conversation.
James
SOHC/4 #3328
« Reply #61 on: May 02, 2007, 06:57:03 PM »
We'll end up with a Heffay ear bashing if we are not carefull ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #62 on: May 02, 2007, 07:17:27 PM »
Sam. ;)
 ;D ;D
Cough, splutter ::)
Damn you Lloyd >:(  You've just made hot tea come out of my nose  :(
 ;D
1978 CB550 K3
1985 H100S
Offline Cowboy
« Reply #63 on: May 02, 2007, 10:34:18 PM »
On the old Chang:
-petcock on
-tickle the float chambers to raise the fuel level until they overflow
-hold the throttle open all the way
-choke OFF
-key OFF
-kick it over a few times to prime the cylinders
-key on
-choke on
-in warm weather, kick once and listen to the girl purr
-in cold weather, kick, kick, curse, kick, curse some more, kick and try to feather the throttle to keep her running
I've adopted more or less the same program with my hondas, without tickling the floats. The hondas start a lot easier than the Chang.
1964 Honda CT200
1967 Chang Jiang 750 Sidecar
1970 Honda CB350
1978 Honda CB550
Offline Rocker
  • The one, the only!
« Reply #64 on: May 03, 2007, 05:10:42 AM »
Wow..this discussion took a turn for the worse.  ;D
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline CrisPDuk
« Reply #65 on: May 03, 2007, 06:59:50 AM »
Got a bit of an echo there Rocker?
1978 CB550 K3
1985 H100S
Offline dusterdude
« Reply #66 on: May 03, 2007, 07:16:12 AM »
i know and for such a tame thread at that.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Dave Wyatt
« Reply #67 on: May 03, 2007, 07:19:21 AM »
Cold starts in cool weather:
Petcock open
Full choke
Two quick twists of throttle
Hold throttle slightly open
Hit the button
After it runs a bit and sounds smooth, push in the choke.
Cold Starts in warm weather:
Petcock open
Full choke
Hit the button
Start riding away and push in the choke.
Dave Wyatt
1976 CB750A
1965 C100
2008 GL1800
I swear, the damn things are starting to breed!
Offline Rocker
« Reply #68 on: May 03, 2007, 07:54:39 AM »
I clicked submit once and it posted it twice. Very odd indeed. I deleted the dup post.  ;D
Strange how that happens. People start talking about petscocks and.......we all know where this is going!  ;D ;D
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline CactusKidMatt78CB550
« Reply #69 on: December 13, 2025, 11:07:18 AM »
On my 76 K6, I have put the later accel pumps carbs from the 77-78 F model....but never hooked the choke up...
So, depending on how long the bike has sat, I will turn on the gas, twist my throttle 4-100 times (lol!), key on, and an easy kick on the lever.
Once it is sputtering, I give consistent mini-strokes on the throttle to actuate the accel pump without opening up the carbs much...and after a moment, I roll away and ride real easy for a few minutes.  70K miles and counting.
Kamal
Thanks for the info, I have a new to me 78, no choke but live in PHX. Easy to start when warm out but colder months was lean and barely idling when starting.
My start up procedures on 78’ cb550 now:
1. Fuel on
2. Ignition on
3. Lean bike straight up
4. 4-6 cranks of throttle for accel pumps and gas in chambers
5. Starter button First start and hold throttle just enough to idle at around 800-1k rpm,
6. Adjust idle up, wait a minute and ride on!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #70 on: December 13, 2025, 05:41:38 PM »
This thread has been resurrected from almost 19 years ago..  LOL
Are any of the original posters still active?
« Last Edit: December 13, 2025, 05:43:51 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
