He's full of sh*t...
It takes about 10-15 minutes to make a spanner to take the rear retaining ring off...about twice that to make a front hub spanner...I use 1/8" steel strap...be sure to drill out the stakes first...
Get new shielded Timken bearings...two 302KDD for the front; and one 304KDD and one 305KDD for the rear...you'll also need a CR 13447 (34x55x9) seal for the rear. I don't have the two front hub seal numbers (axle + speedo) but I did post them in another thread.
If you're using a 750 rear hub you'll need two of the 304KDD bearings + the 305KDD.
I prefer metal-shielded bearings to polymer-sealed bearings.
Considering what he's told you about the bearings, I'd double-check the tightness of the spokes and the trueness of the wheel. Clamp your wheel+axle in a vise, dial-indicate or even just eyeball the wheel while spinning it. It should spin nice and straight with no eccentricity. Next, tap each spoke with a screwdriver; they should all make nice musical notes. If you hear a "plonk" or a "thunk", get your money back...
