SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
mirror vibration on right side
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: mirror vibration on right side (Read 1440 times)
cadler
Enthusiast
on:
May 07, 2007, 11:05:43 AM »
I was out Saturday on my 71 cb750. I noticed that while cruising along my left mirror is clear as a bell but the right one is vibrating. What would cause that, The throttle cable connected to the engine?
Anybody ever notice this?
Logged
merc2dogs
Hot Shot
Re: mirror vibration on right side
Reply #1 on:
May 07, 2007, 11:17:50 AM »
for me it's the left mirror, clear as ever on the right, but the left one vibrates so much everything is fuzzy
I've tried tightening everything up and loosening things up, about the only thing I haven't tried is a little percussive persuasion.
ken.
Logged
cadler
Enthusiast
Reply #2 on:
May 07, 2007, 11:25:01 AM »
I wonder if the vibration is tranfered through the frame to the handle bars and one side of the bars are slightly tighter than the other the vibration will travel up one side.
Logged
Jinxracing
It's hot shit, not
Hot Shot
'70 CB750 K1
Reply #3 on:
May 07, 2007, 11:55:46 AM »
You could try triple ziploc-bagged lead shot stuffed up into the offending end of the bars...might help.
Logged
–Captain Horatio Hornblower
www.thehairynickel.com
WJL75
Hot Shot
Reply #4 on:
May 07, 2007, 12:48:04 PM »
I had the same issue with the stock mirrors, but since I switch to napolean mirrors, I have not had any problems. Are you running stock mirrors or after market?
Logged
wjl75
1976 CB550K Cafe
eldar
Guest
Reply #5 on:
May 07, 2007, 01:42:24 PM »
There has been a lot of talk about cheap aftermarket mirrors vibrating like this. You can try a couple things, you can get a rubber washer and put that on the bolt for the mirror and tighten down but I have not tried this so do not know how well it would work. You can also get a vibration dampener mount. These are supposed to be ok and allow you to tighten the mirror pretty good. ANother option is a steel washer that has a rubber mold around it. More sturdy than just sa rubber washer.
Logged
keepitrunin
Guest
Reply #6 on:
May 07, 2007, 06:42:42 PM »
i have after market mirros and they vibrated until i bought a set of bar end weights from dennis kirk. they were cheap and did the trick for me. plus with the drag bars they look neat too.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
