Author Topic: Rattle Can over Chrome  (Read 1583 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« on: May 07, 2007, 06:45:03 PM »
Anyone had success with rattle painting chrome.
The 185 project has a "engine protect/hwy bar" set up that came with it but the chrome is to far gone to clean, and I'm not paying for re-chroming on this thing.  I'd like to put it on as it will be "new" riders using the bike.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Rattle Can over Chrome
« Reply #1 on: May 07, 2007, 06:51:54 PM »
Get it bead blasted to pit the chrome well and paint should stick to it.  Won't take any major hits but should stand up to washing.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Andoo
« Reply #2 on: May 07, 2007, 07:30:18 PM »
spray it with wd-40 and rub it with aluminum foil
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #3 on: May 07, 2007, 07:52:51 PM »
It's done. Huge stone chips! .......A  little polishing aint going to cut it.
ScottB
« Reply #4 on: May 07, 2007, 10:02:38 PM »
I recently painted a set of mildly rusty exhaust pipes using 00 steel wool and 1 can of paint.  I scuffed the faded chrome surface until it looked like brushed aluminum, cleaned it off and put down two light coats.  About ten minutes after the second one I put down a slightly heavier coat and built off of it until it was solid.
Here are the before and after:
« Last Edit: May 07, 2007, 10:07:32 PM by ScottB »
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #5 on: May 07, 2007, 10:31:28 PM »
1. give a good sanding with a heavy grit sandpaper (80 grit)
2. Go over the entire thing with a scotch brite pad to smooth things out alittle
3. clean to insure their is no oil/dust/crap
4. spray with dupli-color engine enamel (crap is like powdercoating in a can)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #6 on: May 07, 2007, 10:34:55 PM »
"4. spray with dupli-color engine enamel (crap is like powdercoating in a can)"
That was going to be my paint for the job.  Would you want to prime it 1st?
