I just posted 2 pics. of the old girl in the Gallery. The seat is a Windsor saddle that i picked up a few years ago for $20. best investment i ever did for my Bum.
I just finished a run to rest the bike out. it bogged down about 3 times but came back with in a few moments. This time i never went easy on it i cranked it every gear and as much as i did not red line it ( it is a old bike and i cant afford a new engine for it ) I figured if I did this it would heat up a LOT and cut out faster (would a heat shield protect the coils from the heat?). there was heat on all 4 pipes after finishing and i am hoping that it will do better tomorrow.
something i noticed today was that the contacts on the thing (
) that the Fused pos+ wire comes off to the battery was caked solid inside and out with crud from were my old battery was leaking bad last year . I cleaned it up with Brake cleaner and sanded (lightly ) all the leads again. does this have anything to do with spark?
I can get a few used coils from a friend in a few days and try that .
I have a few questions that I hope you can answer (I do hate being a pest ) and they are answered some were on the site But with over 500 posts here I will need new glassed just to complet half of them
. If you can just point me in the right direction to the post for the answers it would be great.
were is the nut for adjusting the timing chain located and
# 2 to adjust the carbs are the adjusters located under the top of the carbs (i like the drill bit methid someone posted here. )
I am starting to feel like a real puts asking so many questions .
who ever started this site should get a Hug or a handshake .
Terry L.
