Author Topic: Specs for CB750 78k Rear Engine Hanger  (Read 1016 times)
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« on: May 08, 2007, 01:32:21 PM »
Does anyone one know the length and thread of the rear engine hanger on a 1978 CB750k?  I noticed the right side foot peg was bent and upon further inspection the peg mount is fine it is the actual engine hanger.  These parts are either out of stock or rather expensive through dealers so I'm looking to buy from McMaster or tread my own stock rod.
eldar
Re: Specs for CB750 78k Rear Engine Hanger
« Reply #1 on: May 08, 2007, 01:39:01 PM »
Well just take the bolt and nut to a place where you can get threaded rod. Measure the length and diameter. Hell you dont even need the nut as the rod will not thread into anything other than the nut so you just buy a new nut to go with the rod.
