Definitely. In terms of utility, it's no problem imo if I only top out at ~100mph on flat ground, and 70mph going uphill into a head wind, but if I could get the bike's engine out of that ~1000-700g/kwh SFC area, I should be able to see some huge improvements in efficiency. Granted, if I go too far, it'll just be slow, but I figure having half throttle at ~75mph would be a good compromise. Ideally, this would be a very tall OD gear, and the first four would remain the same so off the line it'd be just like a stock version. Thanks for the info btw!
