Author Topic: Oil pressure at 2k rpm on oil cooled motors.  (Read 2975 times)
yesplease
« on: May 09, 2007, 05:36:37 PM »
Would there be enough oil pressure for cooling/lube if an oil cooled bike were geared to cruise at 55mph/2000rpm instead of ~6000rpm? Specifically I'm wondering about a CB650SC, but I'm guessing other oil cooled bikes would be similar.
Offline merc2dogs
Re: Oil pressure at 2k rpm on oil cooled motors.
« Reply #1 on: May 09, 2007, 08:48:52 PM »
 seriously aiming for some mileage there?
I don't think there would be a probl;em with the oil pressure, it works fine at 200rpm in town.
 I think the issue would come down to having enough power at 2000 rpm to hold 55mph, a hill or headwind would kill ya.
gearing for that RPM would mean long runs need for getting up to speed, making the bike about useless for town driving.
Ken.
yesplease
« Reply #2 on: May 10, 2007, 09:50:19 AM »
Definitely. In terms of utility, it's no problem imo if I only top out at ~100mph on flat ground, and 70mph going uphill into a head wind, but if I could get the bike's engine out of that ~1000-700g/kwh SFC area, I should be able to see some huge improvements in efficiency. Granted, if I go too far, it'll just be slow, but I figure having half throttle at ~75mph would be a good compromise. Ideally, this would be a very tall OD gear, and the first four would remain the same so off the line it'd be just like a stock version. Thanks for the info btw!
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: May 10, 2007, 10:36:18 AM »
cb650 makes about 9 HP, 20ish lbft at 2k rpm.
That MIGHT be enough to get you to 55mph. I kind of don't think so, though.
No.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: May 10, 2007, 10:42:35 AM »
I don't even think you'd be able to get the bike moving with that kind of gearing, unless you were facing down a pretty steep hill.  Also, wind resistance will probably prevent you from reaching 55mph because the engine wont be making enough power to overcome it.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #5 on: May 10, 2007, 10:46:02 AM »
I was also under the impression that these bikes didn't start charging the battery until about 3k rpm.
No.
yesplease
« Reply #6 on: May 10, 2007, 03:37:56 PM »
Regarding the charging, I think the 84s were better, but who knows? I figure I can really cut down on current use w/ LCDs and a newer headlight, or maybe even go the other way and grab a larger battery.
1984- Minor changes only in 1984; the alternator design was improved to provide a little more charging current at idle and low speed
In terms of power, assuming the motorcycle has a Crr=.65 then I should only need ~6hp at 55mph. Of course, it could be worse, but I would hop not considering Semis have Crrs=~.4-.6. In any event, cutting the power needed at a given speed shouldn't be much of a problem, if I don't mind it looking different. And like I said before...
Quote from: yesplease
« Last Edit: May 10, 2007, 03:50:07 PM by yesplease »
Offline merc2dogs
« Reply #7 on: May 10, 2007, 04:58:42 PM »
only way I can see to do it without massive engineering is to use a jack shaft with a sliding dog clutch, one way to direct couple the I/O sprockets, other way through planetary gearset from a car automatic at 1:2 maybe 1:3
 sure there are other ways, interesting excercize though, got me curious may draw up a few ideas.
ken.
yesplease
« Reply #8 on: May 10, 2007, 05:42:30 PM »
I had a fire lit under my ass after I saw this write up. I dunno how much machining and fabrication would be required, but I'm gonna pull apart a spare transmission I have and find out. There's also converting to FI and running lean, or maybe even cylinder deactivation too, but this seems to be the best bang w/o busting my balls.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #9 on: May 11, 2007, 06:16:58 AM »
Most unfaired motorcycles, with a rider, have a CD of something in the .8 to 1 or higher, range.
« Last Edit: May 11, 2007, 06:22:32 AM by mlinder »
No.
yesplease
« Reply #10 on: May 11, 2007, 10:18:50 AM »
So they literally have the drag coefficient of a brick? At least there's plenty of room for improvements...  :D
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #11 on: May 11, 2007, 10:44:26 AM »
That's correct. With all the nooks and crannies to actually catch air, as well as the irregular rear end throwing all the already turbulent air willy nilly,it can be worse than a flat surface.
Remember CD isn't just a function of of aerodynamics, its aerodynamics + frontal area.
A hayabusa has a CD of mid .5's with a rider (.55, .56, rider tucked in). A naked 650.... well, yeah.
No.
yesplease
« Reply #12 on: May 11, 2007, 02:07:03 PM »
I think you mean CdA.  :P Cd's just a function of how well something moves through the air iirc.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #13 on: May 11, 2007, 02:44:42 PM »
Yes, sorry.
Still, youa rent going to get that 650 anywhere near .65 without crazy aero. Suzuki spent a lot of money streamlining the hyabusa.
No.
yesplease
« Reply #14 on: May 11, 2007, 03:49:00 PM »
Yeah, it'd need to be decidedly streamlined, but I'm pretty sure ~100mpg and functionality could be possible w/ the right fairings/gearing.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #15 on: May 11, 2007, 03:55:56 PM »
If it was enclosed, yes.
Then you run into trouble keeping the engine cool. And it really isn't much of motorcycle if it's enclosed, other than it has two wheels.
No.
yesplease
« Reply #16 on: May 11, 2007, 05:42:34 PM »
Well, everyone's version of what is and isn't something varies, but semantics aside, there are huge gains from even partial fairings. 100+mpg highway is np from a sleek design. having a nose that will allow for a relatively even pressure differential and a decent approximation of a boat tail to avoid the low pressure area behind a bluff body. Even in bicycles this is seen on trikes. Routing the exhaust helps to fill in that area and detach flow farther away from the vehicle. I suppose I could go balls out with a fully enclosed version, but after ~100mpg, the fuel savings really dwindle. No need for some 500mpg streamliner. $300 versus $50 isn't nearly as big of a jump compared to $600 versus $300, and the initial jump isn't as extreme.
« Last Edit: May 11, 2007, 05:44:19 PM by yesplease »
