Well gang... I tore into it again tonight. The good news is I figured out my power loss... I went and bought new air filters and took off the air boxes and covers to change them... then decided to check the butterfly in the carb throat as Raul suggested... and much to my delight/dismay... the slide was moving freely... but the needle was not attatched to the slide! So I disassembled the carbs and fixed that. Threw it back together, and rode it around the block... and now it pulls hard. It sucks that you have to remove the entire exhaust to remove the airbox on these CL's!!!
The bad news... I got back to the garage, and told Paul (paulages) to take it around for a spin... and as soon as he left... the damn bike would not switch gears... It would switch through the gears, but would not engage. Just spin as if you were pulling in the clutch.
I'm hoping it is just a clutch cable adjustment.
Any thoughts?
Cheers, and thanks for all the advice.
Billy/ Portland.
It is possible on the 350 to adjust out too much slack in the clutch cable, usually by setting the lifter itself a little too tightly. When you do this, the lifter can go "over center" when the clutch lever is pulled, requiring you to get your fingers in there and push the lifter arm back to release it. Then, add a little more slack by adjusting the lifter back a little, so the lever can't pull it quite that far.
Worst case: the cable could be rusty/sticky, not letting it release, or the lifter might have old, stiff grease stuck in it. Or, like seaweb, the shaft could be bent a little, making it drag and stick.
But, oh, yeah, those pipes....
![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
