Author Topic: Honda XR Regulators  (Read 1884 times)
Offline LoopsAndLogic
  • Dang IT!!!
Honda XR Regulators
« on: May 10, 2007, 09:24:05 AM »
Is there supposed to be some resistance when checking a AC regulator?
It only has two wires coming off of it. Reason why I ask is because I'm looking into buying a used one.
Any input is appreciated
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Re: Honda XR Regulators
« Reply #1 on: May 16, 2007, 05:06:08 AM »
An ac regulator with two wires is probably what Lucas used to sell as a "Clipper" diode which as i remember is a robust diode (to backwards voltage) that shunts and over voltage on one half of the AC to ground
  • Dang IT!!!
« Reply #2 on: May 17, 2007, 07:35:01 AM »
Would you know where I could fine something like this, or would it be best to purchase the OEM regulator??
I really need someone to clarify, if a regulator is suppose to have O ohms of resistance??
Thanks for the help
LL
My rides:
Past Rides:
« Reply #3 on: May 18, 2007, 05:42:27 AM »
One was has zero ohms reverse has resistance,
What i did with an XL 185 that kept blowwing bulbs was put some 5watt resistors in parrallel with the headlight power wire to shunt some amps to ground, you need to do some math to work out the correct size
  • Dang IT!!!
« Reply #4 on: May 20, 2007, 05:55:27 PM »
Thanks for getting back. And not to make fun of you, but could you explain what you meant.
I really need someone to clarify, if a regulator is suppose to have 0 ohms of resistance??
LL
My rides:
Past Rides:
« Reply #5 on: May 26, 2007, 04:35:31 AM »
Sorry I didnt check the spelling
With your resistance meter on Ohms connect the leads to the regulator  and then reverse the leads.
The leads one way round should have zero resistance whilst the other way should be infinite (really High)
  • Dang IT!!!
« Reply #6 on: May 26, 2007, 11:49:11 AM »
Okay! Now I got it :)
Sorry if that came off a little rude, as I didn't mean too.  ;) ;D
Thank you for the help
LL
My rides:
Past Rides:
« Reply #7 on: May 28, 2007, 07:28:25 AM »
No problem, not rude its my damn dyslexic computer!!
  • Dang IT!!!
« Reply #8 on: May 28, 2007, 07:45:14 PM »
I know what you mean. ;D ;D
One time a seller (evilbay) wrote his entire message LIKE THIS FOR EVERY WORD!!
Low and behold, he was wrong about the part, and after our discussion, he supposedly didn't notice he pushed the CAPS key.
The ??? idiot didn't notice this when he was typing??
I use to work at an Orange Juice factory, but I got canned cause I couldn't concentrate. Just heard this joke. Man, I almost busted a gut.
Then again, my humor is very awkward
LL
My rides:
Past Rides:
Offline 750goes
  • it will live
« Reply #9 on: May 28, 2007, 08:11:11 PM »
Loops
I think you are taking the Pith..........................
Offline crazypj
  • I'm brill, me
« Reply #10 on: May 29, 2007, 06:40:55 AM »
LL
 I often dont notice  That I've hit THE CAPS LOCK, I cant type so I look at keyboard instead of screeen, its only later when I'm postinbg message I see what i did. I usually go back and re-type, but this is what often comes ou
 ( totally uneditied or moidified)  :D :D
 PJ
