3 quarts , when i changed the oil i drained the filter , oil pan , and tank . not a whole lot came out since it'd been spewing it all over my leg . but even with it as low as it was it'd still dribble out when i came to a stop . put in a new filter , and filled the tank with 3 quarts , kill switch off kicked it till the oil pressure light went off . came to a stop and supprise supprise , oil ,plenty of it . the oil light never flickers , and the engine runs great , nothing out the valve cover breather except alittle vapor . but this oil tank just won't quit overflowing . i'm at witts end and completely out of money now ( it's all inside the bike now) there is no reason at all it should do this , the only possible thing i can think of is the breather assembly inside the tank has a drain to let oil that gets in there go back into the tank instead of out the breather . that could be plugged up , but theres no way to get to it because it's inside the tank . i so hate this bike
edit: and it seems more like a sloshing problem , if i hold the front brake and rock the bike once it's warmed up i can get oil out the breather too .
